will nitto 305's fit in wheel well?
I was looking on the sticky at the tires and rims that will fit are cars,
REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 295
10.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
My question is from other threads saying the Nitto's run small? SO, would the Nitto 305x35x18's fit a 18x10 inch rim w/54 mm offset even though the sticky says no. I know the tire will fit on the rim properly, i'm more concerned with rubbing in the wheel wells?????
REAR Only
REAR Only
REAR Only
It should fit, but may need some "massaging" in areas of the fenderwell to make sure it doesn't rub...
thanks for the reply...i think i'm going to return the 305's and go to the 285's.
I know the 285's will fit...i have 295's in there now... i wish Nitto drs came in 295's.
