Help With picking wheels for track only
Old 02-11-2009, 08:32 PM
witry's Avatar
Default Help With picking wheels for track only
ok well my car is a DD and i go to the track about 5 to 10 times a year we are in the process of doing H/C and boost so i want to get a set of rims just for the back to put on at the track or a good street run saturday night
i know that i can get a 15x10 with 7.5BS or a 15x8 with 5.5BS but which ones fill in the trans am wheels wells better and not have to modifty the fenders or the inner fender and which tires to get with which rims so they dont rub
thanks matt
Old 02-12-2009, 02:00 PM
witry's Avatar
anybody have any suggestion nothing
Old 02-12-2009, 02:01 PM
streetassasin's Avatar
bogarts
Old 02-12-2009, 02:18 PM
witry's Avatar
bogarts?
Old 02-12-2009, 02:20 PM
witry's Avatar
nm bogarts brand... im getting welds but dont know what size would look and fit best 10x15 7.5bs or 15x8 5.5bs
Old 02-12-2009, 02:21 PM
oh gotcha 10x10 will fit fine just roll the fender grind the caliper and maybe bfh
Old 02-12-2009, 02:27 PM
witry's Avatar
how much do i have to grind the caliper alot or just a tad
Old 02-12-2009, 02:28 PM
not sure, you have to grind them if you go with any weld but dont with the bogarts
Old 02-12-2009, 02:33 PM
witry's Avatar
hmm really them i might have to check them out, also with the 15x10 it shouldnt rub on the inside right?
Old 02-12-2009, 02:34 PM
depends on what size tire, that why I said you might have to do the bfh
Old 02-12-2009, 02:37 PM
witry's Avatar
cool thanks for the info
Old 02-12-2009, 02:39 PM
no problem
Old 02-12-2009, 02:55 PM
my06tbssson's Avatar
i say bogarts as well i have heard that the brake caliper is to big on the stock 10 bolts for welds...... yes a 15x10 will fit you can run up to a 315/15 with a 17" wheel not sure on sizes bigger than that but my dad is tunnin 17x12"s on his t/a and it doesnt rub so maybe tthis will help man good luck oh and i would suggest you upgrading the rear if your gona be makin good power
Old 02-12-2009, 03:06 PM
witry's Avatar
i have a 12bolt at home but im ganna wait till this one goes i want to see what i can get out of this 10 bolt, prob not much more but hey ill see
Old 02-12-2009, 04:23 PM
BIG_MIKE2005's Avatar
I opted for Centerline Convo Pros so I wouldn't have to grind at all. I also only make it to the track a few times a year & that just doesn't justify grind my caliper or buying race brakes & definetly not dropping the coin for Bogarts.
Old 02-12-2009, 05:11 PM
witry's Avatar
^^^^^they fit with out any issues?
Old 02-12-2009, 07:35 PM
SJM Manufacturing Inc's Avatar
Our Bogart's can be built specific for your car. They will bolt right on front and rear. They also tuck better than other options on the market. They will be the lightest, direct fit wheel you can purchase. Using our wheels will be like dropping about 50 converted static pounds off your car over most other manufactures drag wheels.
We have a very good resale rate so it is a good investment, in fact, if you can find a used set, I'd consider them. Just make certain if they are used, that they were designed for your car as just because the wheels is called a D10 for example, we can build them in a variety of ways with the same backspace.
Pricing varies according to builds. Give me a call if you would like to discuss your options. Our designs are not the most expensive on the market yet they are not the least expensive. Actually what you reap in benefits, if you purchased centerlines or prostars, you'd have to also purchase a k-member to equate similar weight losses. By that point, you actually spent more then what you would have by purchasing our wheels by themselves! Below is exactly what I'd suggest for a strip tire/wheel combo. You will reap the best track gains out of this direct fit setup over any other combination.
In the meantime, you can view many cars listed on our F-body gallery from the link below my name.
here's one of our setups which I thought looked rather nice. This one we named after one of the LS1tech board members.
Old 02-12-2009, 07:46 PM
2000_SS's Avatar
^ that's one of the best looking set of Bogarts i've seen on here. i've been considering the floyd's for my SS.
One question i have for you, Steve, is what other wheel designs are there? i noticed a member on here with a white TA sporting a set he refers to as "GT's", which i can't find listed on any site. i like how they look too, but have only seen the pictures he posted. it made me curious as to what else may be out there.
Old 02-12-2009, 08:13 PM
The GT was an offspring of the Floyd. We haven't updated it onto the site (the whole site is being revamped btw). The difference is at the very edge of the spokes. The Floyds have a slight radius edge. It's a small difference some may not notice. I think there are some pictures of them in the gallery; it's just not updated in the P1 section.
Occasionally we create offspring designs. Customization is something that we boast. We want each customer to walk away satisfied with nothing but positive experiences. As I mention quite often, wheels make the car. It's one of the most noticeable modifications you purchase. If design/fitment and weight benefits are important to you, then we should be on the top of most folk’s lists when it comes to custom wheels.
Old 02-12-2009, 08:16 PM
Btw, they all look fantastic in my eyes (biased of course). Occasionally some stand out more than others. This is due to the person taking the picture using good lighting and or cameras.
In person, if you see one, if you're at the track or in a parking lot showing your car, no matter which style is used, it does get noticed and stands out above the rest.
