Any 17" skinnys out there
Old 02-15-2009, 03:53 PM
Randy WS6's Avatar
Default Any 17" skinnys out there
Im thinking of having my WS6 front rims narrowed to 4-1/2",does any one make a skinny 17" tire, I have my rears widened to 11" with Hoosiers DR-335/35/17. I know i can buy aftermarket rims in 15" but i want to keep my 17's if possible
Old 02-15-2009, 03:57 PM
itsjustaSB's Avatar
m&h makes a front skinny in a 17 i think it takes a 4 inch rim
Old 02-15-2009, 06:40 PM
Camaro396's Avatar
Hoosier makes a 17" skinny that is a street tire.
Old 02-15-2009, 08:33 PM
Randy WS6's Avatar
This what I found, Witch one should i get.
http://www.mandhtires.com/store.php?...on=show_detail
4.5/26.0-17 D.O.T
**FRONT RUNNERS-TREADED**
Tread Width: 4.5"
Section Width: 6.0"
Diameter: 26.0"
Circumference: 81.2"
Rim Size: 4.0"
Code: MSS-17
**D.O.T. Certified**
http://store.summitracing.com/partde...5&autoview=sku
Hoosier 19055
:HOO-19055Tire Size:26.00 x 7.50-17Rim Diameter (in):17 in.Sidewall Style:BlackwallTire Construction:RadialDirectional:YesSection Width (in):7.30 in.Tread Width (in):5.30 in.Speed Rating:HMinimum Recommended Rim Width (in):5.00 in.Maximum Recommended Rim Width (in):6.00 in.Asymmetrical Tread Pattern:NoDOT-Approved:YesTube Required:NoMax Load Single (lbs):825 lbs.Quantity:Sold individually.Tire, Pro Street, LT 26 x 7.5R17, Radial, 825 lbs. Maximum Load, H Speed Rated
Hoosiers
Old 02-16-2009, 12:02 AM
SJM Manufacturing Inc's Avatar
M&H tires are very nice tires. Actually, if you look closely, the wheel that the tire is mounted on is one of our Bogart prototype drag wheels. 4.5" is a good width.
I don't think you're wheel will look very good narrowed. It's up to you. They are probably going to only cut the inner hoop so I don't know how much you have to work with regarding having the wheel still tuck under the fender area.
Old 02-16-2009, 07:47 AM
Randy WS6's Avatar
I could go with the Hoosiers they require a 5"to 6" rim. As for looks the tire will set out just like factory ,They remove the the inside lip and move toward the center.They dont remove the center it self ,they cut the inner lip about 2"in, and then remove up to the inside edge of the spoke then add the 2" piece that they cut off ,I think the WS6 rims has a 1-1/2"to 2" offset, I cant really remember. If its 2" offset the tire would be centered in the rim. for a 4" rim. and for a 6" rim they would first cut 4" from the inside lip.and remove excess to achieve the total of 6" added to the 2" offset.
Old 02-17-2009, 09:28 AM
Randy WS6's Avatar
Is your rim off set from the (out side to the center) the same as the factory rims.
Old 02-17-2009, 12:28 PM
C5_Pete's Avatar
Where do you get your rims narrowed?
I have searched and found nothing - wheels america wont do it.
Old 02-17-2009, 02:47 PM
jjordan's Avatar
Weld makes a 17x4.5 front runner in either the Alumistar or Magnum designs. Have munted up the Hoosier tire on this rim, it is a good looking setup, I have not actually seen the M&H tire but have heard it is nice.
Old 02-17-2009, 07:25 PM
JGKadell's Avatar
pick up some GTO spares
Old 02-17-2009, 09:01 PM
Camaro396's Avatar
Old 02-18-2009, 07:51 AM
Randy WS6's Avatar
Wheels America in Dallas TX. will do it . I called them and they told me no problem ,a 2&3 day turn around and 150.00 a rim to narrow my 17x9 to 17x4-1/2" hers there sight>> http://69.15.156.118/Sites/wheelsame...?page=widening
Old 02-18-2009, 10:58 AM
slow's Avatar
The ws6 wheels are a tapered barrel rim, I do not think they will be able to narrow them easily. Widening, yes, but narrowing, would be much harder to do, since your cutting out transition material from them.
Ryan
Old 02-18-2009, 11:20 AM
C5_Pete's Avatar
Good to know, Thanks
Philly W/A wont do it.
Old 03-01-2009, 06:55 PM
Randy WS6's Avatar
What size tire & rim are these, I know there 17" but how wide and what tire ?
Originally Posted by Camaro396
Quick Reply: Any 17" skinnys out there
