What exact offset for TTM's?
I got 315/35/17 nittos DR's and 275/40/17 F1's for front. I understand from the stickies these will fit the TTM's 17x9 and 17x10.5, but my question is what exact offset I want for the rims in order for this combo to work properly w/o spacers and fender rolling and such. Also am i correct in thinking that even tho the sidewalls are different sizes, they will look the same? According to a tire calculator I used, it said both sidewalls would be 4.3".
I have 17"x9" on all four corners . . .the offset is 44mm, Backspacing is 6.85, and they weigh 21.8lbs. I'm getting the 10.5's for the rear and they have a 44mm offset, 7.55 backspacing, and they weigh 22.5lbs. Hope that helps!
