What tire pressure for front runners or skinnies?
Old 03-01-2009, 08:45 AM
faster_n_you98's Avatar
Default What tire pressure for front runners or skinnies?
I just picked up my set of Greg Weld front runners and a set of moroso ds-2 tires and i have searched here and looked at the instruction manual my tires cam with (J/K) and can't seem to find what a proper tire pressure is for these guys.
Old 03-01-2009, 10:58 AM
white00ta's Avatar
I would assume around 35psi. Might be able to run 38 or so but might wear the tire a little uneven. S
Street: 32-36psi
Strip: 35-max tire pressure rating. "less rolling resistance"
Old 03-01-2009, 11:06 PM
really? I figured it would be less because it is not a radial.
Old 03-02-2009, 12:20 AM
2XR95Z28's Avatar
What about the MT Sportsman? 35+?
Old 03-02-2009, 12:41 AM
Are you saying you run that in your sportsmans?
Old 03-02-2009, 01:22 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I run around 35 or a little more in my Sportsmans
Old 03-02-2009, 06:18 AM
Photochop's Avatar
I've always gone 2-3psi less than max pressure for the track (they'll pop up a couple lbs when warmed up). More air = less rolling resistance.
Old 03-02-2009, 01:06 PM
silverbeast's Avatar
I run around 45lbs in mine. Anything less and the weight of the car makes them look like they are going flat.
Old 03-02-2009, 05:29 PM
solo21's Avatar
I agree! I had 35lbs on mine. for some reason It didn't look right....not only that I was tired of scraping the plastic underneath when you catch any kind of speed bump or small dips. So I put it up to 40lbs
Quick Reply: What tire pressure for front runners or skinnies?
