what size tires?
what size tires?
hi im new to this site. i recently bought 4 18x9.5 c6z06 rims for my 94z28. i havent bought tires for it yet. i was wondering what size tires i should go with. i was thinking 275/35/18 or 275/40/18 for back. should i go smaller in front if so, what size? should i go R35 or R40? if anyone has any suggestions they would be greatly appreciated thx.
Just went through this same dilemma. I went with the 275/35/18 all around
after finding out that the 40 was 1" taller than the 35s. I am lowered so I didnt need more tire to fill my wheel gap. If your not lowered you may actually want the 40 to help fill the gap. Also read the 1" diff in tire throws speedo off about 3mph, just keep that in mind or have it reset. The 285 is an option in the rear if you dont mind not being able to rotate tires.
Also, after researching Im probably going to run some sort of adapter/spacer to bring the rears out a little. The C6s I ordered have a 56mm offset.
