Ordereing ttm but not 100% sure correct specs..
Old 03-24-2009, 08:27 PM
MY99TAWS6's Avatar
Default Ordereing ttm but not 100% sure correct specs..
I think its 17 by 9 bolt 5-4.75 inch 45mm offset but is 6.89 correct backspace?
And for back 17 by 10.5 44mm offset? with 7.5 backspacing? 4 -4.75 bolt pattern.
Think saw one site said 23mm offset on back and 4.5 inches on front?
So want to make sure get the right ones.
Old 03-25-2009, 12:27 AM
Turnin20s's Avatar
Well my ZR1s are 17x9 all around with a 56mm offset and the rears in 11" come in either a 36mm offset or a 50mm offset. I personally like the look of the 36mm offset since they don't stick out too far, but may reguire you to beat in the inner wheel wells
hope that helps
Old 03-25-2009, 01:43 AM
Donohue96M6Z28's Avatar
Thats the correct offset. The same offset that is currently on my car.
Old 03-25-2009, 01:44 AM
hope that helps
36mm would actually push the wheels outward. Meaning, you'd have less of a chance of needing to 'beat in the inner wheel wells' when compared to a 50mm offset wheel.
Old 03-25-2009, 11:47 AM
Turnin20s's Avatar
Really??? All of the pics I have seen the 50mm offset seem to stick out farther than the 36mm. Or mabye I'm just dumb LOL, I thought it was the other way around, but you are right....
36mm offset = 7.4" backspacing
and
50mm offset = 7.9" backspacing
Thanks for clearing that up man, now I will deffinately be getting the 50s HAHA
