Nitto 555r tire pressure
Old 03-27-2009, 02:55 AM
Trevors00ss's Avatar
Default Nitto 555r tire pressure
Just got my new tires today, Whats a good tire pressure for 275/40/17 555r's on the street ?
Old 03-27-2009, 12:35 PM
NebWS6's Avatar
whatever they hook best at
I run mine at 34psi front, 32 psi rear... If I was going to drag it then I would lower the rear quite a bit.
Old 03-27-2009, 02:44 PM
shaun's Avatar
from what most guys on here say any more than 30 will make the centers wear out faster.
i run about 28 on the street and at the track ill go 22-20 depending on how the track hooks.
Old 03-27-2009, 03:08 PM
Blknight6989's Avatar
For street driving I run mine at 26-28 and if I'm gonna race or at the track drop them to 18 and they dead hook!...GMHTP did a test on em and found that 18 or 19 psi seem to hook best for these tires.
Old 03-27-2009, 04:45 PM
01Z0H6's Avatar
28lbs in mine...
Old 03-27-2009, 05:08 PM
tspence45's Avatar
I ran my 275/40/17 555r's at about 30, and the centers wore out faster than the outter parts of the tire. So, I'm running my 315's at around 27-28 now. Hopefully that'll keep the centers from wearing down faster.
Old 03-27-2009, 08:19 PM
SS SLP2's Avatar
I'am witch u, on pressure, but I never could "dead hook"
I ran them year round on street and several trips at track (8-12 passes)
one set about 4300 miles total, one set 3200 miles
now on MT' may get 800-1k on them
my .02' Johnny
Old 03-27-2009, 11:35 PM
Thanks, sounds like i'll try 28psi
Old 03-28-2009, 12:02 AM
Ls1Rook's Avatar
At the track and street i use 30 psi, but im stock stall/small bolt ons... so no need to lower the psi got a 1.9 60 ..
Old 03-30-2009, 08:38 PM
maxgee's Avatar
i have 4k miles on mine with more than half life still left, they have 2 autox's on them and one track day....still plenty of life. I think the heat cycle I had done gave them extra life.
Old 03-30-2009, 10:59 PM
Formula_LS1's Avatar
I keep mine at like 23psi all the time. I found that with about 25psi or more that they wear unevenly.
Old 03-31-2009, 12:59 AM
c0ncEpT's Avatar
Exactly.
My 1st set of Nittos were run at around 30psi and the center wore much faster than the sides.
My 2nd set was run at about 24-25 and the centers still wore out faster but they were much more even.
If I were to get another set I would run them at around 23psi
Old 04-03-2009, 12:41 PM
02yellowls1's Avatar
when daily driving i ran mine at 30psi. at the track id drop them to 19psi. when new they hook sooo good.
Old 04-03-2009, 01:32 PM
1bdtrk's Avatar
Location: Currently, Zormat, Afghanistan....Home staion, FT. Richardson, Alaska
I ran a used set all last season (315/35/17). ran them at 35psi on the street (about 3 weeks before i bought my y2k's) and 19psi on the track. They hooked perfectly all year and I dump the clutch off the line at 6K. got 3 consecutive 12.9x passes on them at the end and you couldnt even begin to see the tread pattern. These are some awesome tires.
Quick Reply: Nitto 555r tire pressure
