TTM tire size question
Old 04-01-2009, 11:47 AM
AR15 guy's Avatar
Default TTM tire size question
What size tires are you running on the 17x9'' front and 17x10.5 rear? Tire rack recommends 245/45/17 but shouldn't a 275/40/17 fit fine? And I guess 315/35/17's for the rear?
Old 04-01-2009, 01:22 PM
Donohue96M6Z28's Avatar
275 fronts, 315 rear. Same set up Im running.
Old 04-01-2009, 02:32 PM
udienow's Avatar
What he said... 275/40/17 front, and 315/35/17 rear to be exact.
stickies can tell you more if you need it:
https://ls1tech.com/forums/wheels-ti...must-read.html
Old 04-01-2009, 04:24 PM
AR15 guy's Avatar
Thanks. I may just get 17x9's all the way around then. Not sure if I want to run 315's. Actually...I may get 6 TTM's then....4 with 275/40/17 street tires and 2 10.5's with drag radials.
