Anyone running Centerline Telstars?
Old 04-04-2009, 07:06 PM
Lt4TransAm's Avatar
Default Anyone running Centerline Telstars?
I was wondering what backspacing i need for the rears? Should i get 15''x10'' or 15''x8''? What all do i need to do to get them to fit on my car. I already have the fronts.
Old 04-04-2009, 08:00 PM
tillery's Avatar
will not fit LS brakes I have tried and way too much grinding is required. Will fit lt brakes tho.
Old 04-04-2009, 08:06 PM
93blcZ28's Avatar
That money must really be burnin lol
Old 04-04-2009, 08:07 PM
93blcZ28's Avatar
He is going to have to shave his caliper down, it will work
Old 04-04-2009, 09:19 PM
Lt4TransAm's Avatar
For the fronts or the rears?
Old 04-04-2009, 10:30 PM
tillery's Avatar
I have longer studs on my car. I ran a spacer on the front, and had ground down one the rears alot more than should hav. and still didnt fit. I have seen it done. with alot of grinding. I was going to swap to lt brakes-which they will fit. but went different wheels.
Old 04-05-2009, 09:33 AM
pmbmax's Avatar
I have them on my car never ground anything but my rear is narrowed 5 iches. I have had them for 5 or 6 years now
Old 04-05-2009, 10:49 AM
tillery's Avatar
What year is your car? and the rear being narrow will allow the rim barrel possibly clear the brakes. On LT cars these will fit no problem. But LS brakes will fit with a thick spacer on front. But rears stock width with alot more grinding than welds. or you can switch to LT rear brakes. The Convo line will fit no prob.
Old 05-03-2009, 10:54 PM
Lt4TransAm's Avatar
BUMP! What offset & what backspacing do i need? 15x8? 15x10?
Old 05-03-2009, 10:58 PM
ls1ow's Avatar
i had them on my 99 i ran a spacer on the front and had to grind the rears down to nothing it was a pain in the ***, i would say running that wheel is not worth it, they weight more than pro stars and are a pain in the *** to get on just my 2 cents.
Old 05-05-2009, 11:06 AM
Lt4TransAm's Avatar
Bump!
