Balancing rims with slicks
How many of you are balancing your wheels with slicks? I have been told it defeats the purpose, since after a few good burnouts the balancing changes,
One of my Hoosiers took 11 ounces. I asked the guy that mounted it why he didn't break the tire down and turn it 180* so it would take less weight. He said the sidewall was so thin he was afraid of destroying the tire. I had told the guy not to lube the tires because I was worried about them turning on the wheels.
Problem I am having is, I have the older Weld Draglite 90 series wheels 15x10, they have a floating spacer in between the center of the wheel that aligns up when you put it on the car with the lugs, it seems to be moving when they put it on the digital balancer and it throws the balance #s off, heck it needed 62 1/2 oz WTF, Jegs told me it requires some special piece to hold this spacer aligned in the wheel when you balance it, so I dont know what or where to go to get them correctly balanced, I put them on the car and went out and drove it, up to 90mph it seems ok, I mean 62 1/2 oz out of balance you would think it would rattle my teeth loose...lol anyone else use these wheels or experiance this ordeal? Thanx.
Unless you put screws in your tires to keep them from spinning on the rims, balancing is pointless, even then i garauntee you after several passes if you carry them back they will be out of balance. I do not balance slicks anymore and have not for years because of these issues, and my cars ride great. Not to mention when you sling that weight of on the track its like a bullet whether you are doing your burnout or making a pass, and the next guy to make a pass probably wont appreciate hitting it with his tires. I do not balance drag radials either, but i do keep my front wheels in balance.
The best way to balance a slick, is to do a good burnout on the tires. This will help to round them out. I have have slicks that have needed several ounces before also. Then I did a nice burnout on them and they didn't need as much. It would be a bad idea not to balance them. Wheel vibrations at 100+mph sucks! Good luck
