has anyone ran factory c6 18's&19' on 01z
Old 04-10-2009, 12:06 PM
ryans01z28's Avatar
Default has anyone ran factory c6 18's&19' on 01z
wondering if anyone has ran thoes rims & tires on an 01 z. will I need spacers? will the rims fit?
Old 04-10-2009, 01:16 PM
ryans01z28's Avatar
I want 2 run c6 18's &19's on a 01 z28 will they fit?
Old 04-10-2009, 02:32 PM
one fast zo6's Avatar
YES THEY WILL FIT but you will need 1-1/4 adapters for the rear wheels
and i have a set that are like new with all the lug nuts.
Old 04-12-2009, 02:16 PM
SLV_WS6's Avatar
My brother put these on and didnt have to do to many mods to it. He had to use a thin wheel spacer on the rears. Worked fine
Attached Thumbnails has anyone ran factory c6 18's&19' on 01z-new-wheels-x-2-070.jpg
Old 04-12-2009, 03:08 PM
2fast97Z's Avatar
1 1/4 spacers for them to fit? holy ****! they are 65mm offset so from 58-65 you have to use that big of spacer?
Old 04-12-2009, 03:43 PM
SLV_WS6's Avatar
No adapters needed! It was either a 1/4 or a 5/16 wheel spacer. WE did have to hammer in the wheel well in two places on each side. Nothing major though. Not the lip.
Old 04-12-2009, 04:01 PM
Bregedur's Avatar
I have them on a 99 Z now. Had to use a small spacer and did a little of the bfh mod just to be sure it would clear on the rears, but the fronts didn't have a problem.
Old 04-12-2009, 04:08 PM
spaz1's Avatar
Make sure you check how many threads you have if you use a spacer. You may have to use longer studs. The 1" and up spacers bolt on and have their own set of studs.
Old 04-12-2009, 04:10 PM
SLV_WS6's Avatar
Nope no longer studs needed. It worked perfect. We had no problems.
Old 04-12-2009, 07:24 PM
DriftR's Avatar
OEM C6 rear wheels are +79 offset. Most are using the 1.25" adapter to bolt over your existing studs to fit them and keep from rubbing on the inner fenderwell.
Old 04-12-2009, 08:10 PM
STREETRODZ1's Avatar
Vette wheels on my 95 fit great with a little BFH on the inners in the back, nothing drastic, works like a champ, no rubbing.
Old 04-12-2009, 10:21 PM
DriftR's Avatar
Here's some more info for you from another thread.
https://ls1tech.com/forums/wheels-ti...-got-them.html
Old 04-13-2009, 07:23 PM
ryans01z28's Avatar
ok so 1 1/4 spacers or no? theres two ppl that say two differnt things
Old 04-13-2009, 07:35 PM
enigmah's Avatar
^^^ me too i have the 68+mm offset comming will i need a spacer?
Old 04-13-2009, 09:38 PM
1994formulalt1's Avatar
oh man i'm buying some this week and i'm going to try it out with a 1/4 inch spacer since the guy is throwing them in with the deal
Old 04-13-2009, 10:03 PM
DriftR's Avatar
We need to be sure which which wheel your using. The thread title says "Factory C6 18/19".
OEM C6 vette wheels are +79 rear offset, not 65 as mentioned in post 5. Follow the link I posted earlier, there are more links and info in that thread that should help.
Old 04-13-2009, 10:12 PM
SLV_WS6's Avatar
Had these Factory C6 18/19 wheels on the 98 Red anniv SS pictured below and did not need any adapters just a thin wheel spacer, and did not have to replace with longer wheel studs...but do whatever you think
Old 04-14-2009, 10:02 PM
ryans01z28's Avatar
ok thanks ill try them without adaptors
