Drag skinnies; does the diameter really matter?
Sorry if this is a repost, I did a search but didn't find anything.
I know that it's important to take your setup into account when calculating the proper diameter for your rear tires. My question is, does the diameter of your front tires really matter? I know that you'll get brake/ABS warning lights if your fronts and rears have different diameters, but I'll just be using the skinnies for the track. Wouldn't it make sense to use the smallest diameter available in order to save the most weight? I've been looking at these 22.5" tall ET Fronts; supposedly they only weigh 7 pounds each, much lighter than the taller sizes (next lightest is 11 lbs). That's a lot of weight reduction at the outside of the rotating mass!
http://store.summitracing.com/egnsea...0+115&y=2&x=30
Would I run into any issues at all with a diameter that small on the front? If not, then why would someone run a taller (and heavier) front skinny? Having a wheel/tire combo on the front that only weighs about 17 lbs each side (15 X 3.5 Draglites, about 10 lbs each) would be pretty sweet.
A 22.5" tire is 3" shorter and will effectively lower your front end 1.5". In addition a lot of these cars have traction control (ASR-Slip regulation). If your car has it you will have disable it in order to prevent errors from the front and rear sensors reading differently. If you can handle both of these, a small tire can be used.
My car is stock ride height so I don't think the drop in height should hurt anything ("4X4" look, huge wheelwell gaps) and I don't have traction control. One time I put a larger tire on the back and my ABS light came on but I didn't notice any adverse effects at all.
By having the biggest front tire you can get will lower your E.T. at the strip. This is because the beam isn't activated until it isn't being blocked any more.Having the bigger tire will basically make the track shorter.Plus it will probably help your weight transfer for launching.Me personally, a bigger front tire looks good.
I guess this would be more appropriate for my application?
http://store.summitracing.com/partde...5&autoview=sku
