17" Billet specialties questions.
Old 04-14-2009, 05:20 PM
JBourne's Avatar
Default 17" Billet specialties questions.
Been looking at wheels latley and the 17" B/S Street lights are growing on me. But I do have some questions before the purchase.
My car (Camaro) is lowered on a pro-kit (About 1.5 inches) and I have an adjustable PHB.
Also, I will be getting some 15x10's w/slicks for the track. Below is just for my street set-up.
Rear:
Will these stick out the wheels wells? A few pics of them I have seen on cars, they look like they might stick out a bit. Due to the angle, I can't be certain.
What tires to go with. I've seen Nitto's on them and they look small. What do you guys think about the Kumho XS's in either the 315/35/17 or 335/35/17? Do you even think I should attempt the 335's. I am not shy to bash on my inner fenders or roll the lips to make them fit. How about them new Toyo Q's in a 315? I want a mean/aggessive look, but I don't want it to look gay.
Front's:
Should I go with the 17x7's, or 9.5's? What tire size would I go with for either? Anyone make a matching set of performance tires that will work for the front and back?
Like I said, this is my street set-up and I will be using the front 17's for my drag as well.
Old 04-14-2009, 05:26 PM
Turnin20s's Avatar
Rear:
Front's:
Just don't go with 7s on the front, I hate it when people put a wheel that small on these cars unless its a slicks/skinnies setup.
I say 17x9.5s up front and 17x11s and a 275 front and a 335 rear. Thats what I'll be doing unless I go 18s, but 17s look really good on these cars
Old 04-14-2009, 05:39 PM
JBourne's Avatar
I'm kinda on the same boat. I don't think the weight savings is the priority for me (Even though I like light stuff), if it were the case, I would have a spindle mounted Bogart.
************** Also, My car does have ground effects so a little gay is ok, but not a whole lot.****************
Old 04-14-2009, 05:58 PM
DopdBrd's Avatar
I don't see why you woudn't go 7's on the fronts. Buddy of mine here in town has them and I will hopefully be getting them soon.
If you want to use the 7's for double duty (track/street) why not get them and not the 17x9.5's?
I pretty much plan on doing the same you are going to do.
17x7 w/ 215/50R17
17x11 w/ 315/35R17
then a
15x10 w/ 28x11.50R15 ET Street for the track.
17x7/17x11 Combo looks killer
Old 04-14-2009, 06:07 PM
Emoney97ss's Avatar
a 335, is really hard to fit on those springs.. i have them and i cant even accelerate hard cause it buts the car on the tire. i have 17x11 tt2s i'm not sure if the backspace on these rims will push it in more but my setup doesn't work to good..
Old 12-15-2009, 08:44 PM
Hawk170's Avatar
just ordered 17" x 7" F and 17" x 11" R . Ill take pics when i get them.
Old 12-15-2009, 08:59 PM
Giddswat's Avatar
I like the 9.5 up front and the 11 out back with MT 295-45-17 Street Radial out back. Someone just posted up some pics on here with that setup and it looked great, I`ll see if I can find the post in a few.
Old 12-16-2009, 02:45 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,096 Likes on 720 Posts
I know a few folks with the 17x7/17x11 combo, looks nice. Let me see if I can find a pic.
Old 12-16-2009, 04:27 PM
Giddswat's Avatar
Here`s the link in reference to the rear tire size, I think this would look good on a 17x11 B/S Street Light. I think the front looks good with the 17x7, but if it was my car I would run a 17x9.5 up front(Some Day)
https://ls1tech.com/forums/wheels-ti...17x11-rim.html
Old 12-16-2009, 04:55 PM
airforcemanss's Avatar
does anyone know the weight difference roughy between the 17x7 and 15x3.5? i like the idea mentioned in this thread about the double duty for the fronts and just swap rears for the track. but of course the main concern would be how much would those 17x7 really affect weight transfer?
on a side note, has anyone seen a 17" front with a 15x10 rear with a big tire radial? for people throwing down some power on the street don't you think a 15x10 with a 28" radial be ideal?
waiting on the pics john
Old 12-16-2009, 08:11 PM
223HAWK's Avatar
One of the best looking 17 inch wheel for an F-body I think..I want 18s but cant afford Fikse or CCW..so this is what I got!
17x9.5s and 11s out back Cant remember offsets but it was for an F-body..
I think the stick out just enough to look bad ***..Looks Tuff but still classy..
Nitto 555s
275,315. The street tires look much wider than the drs.
Go with the 9.5s the 7s wont like corners as well..and tire selection is a lot better..
Took most of these last week..
Be prepaird to polish and polish..I take the wheels off and do the insides everytime..thats how you keep um lookn new!
Old 12-16-2009, 10:04 PM
LS1Tech Co-Founder
17x7, and 17x11, not the best pics, I didn't take them but am posting them with permissions:
Old 12-16-2009, 10:08 PM
LS1Tech Co-Founder
15x3.5 = do not fit with stock brakes
15x4 = 10.5 lbs
17x7 = I'll ask and post tomorrow
Old 12-17-2009, 09:15 AM
LS1Tech Co-Founder
Billet Specialties Street Lite Wheel Weights:
15 x 4 = 10.5 lbs
17 x 7 = 19 lbs
17 x 8 = 20.3 lbs
17 x 9.5 = 21.8 lbs
17 x 11 = 23.6 lbs
Old 12-17-2009, 01:25 PM
thanks john.
have you guys seen the inserts for them? i think they look even better. hey john, if that's one of your customers car you mind asking him if he's seen the inserts on the street lites ( hint, he has the same car/color as me)
edit: look at these pics of the inserts. what do you guys think? john, you probably seen this thread already but this is what i was talking about.
https://ls1tech.com/forums/wheels-ti...seen-lite.html
Old 12-20-2009, 05:26 PM
LS1Tech Co-Founder
I've seen some customized B/S Street Lites with parts of the rims blacked out. They look pretty nice. B/S has thought a bit about offering that the public.
Old 12-20-2009, 10:02 PM
LS1 Sounds's Avatar
Rear:
They don't stick out on my Camaro, they sit perfect IMHO with 17x11 and 17x7s. I don't like the look of the Nitto DRs on an 11" wide wheel, but some people like them and other Nitto tires have wider tread width. I have the Toyo DRs on mine, which are about the same width as the MT DRs. I don't like them as well as the MTs though, so MTs will be going on next. I had to roll the lips on mine, but didn't have to bash the fenders in. I am on stock rear springs with the hose mod + 1 full coil cut off. They definitely don't look gay!
Front's:
If you are using the same fronts for drag racing, definitely go with the 17x7s. My car is a daily driver that I like to run at the track in the same trim that I drive it, and these are the perfect wheels for me. I like having the option of getting a 15x10 down the road for track days if needed. I have DD on 15x3.5 and 15x10 Welds before and hated it, these are the perfect wheel for me. I bought the cheapest speed-rated 215/50R17 in stock at DTD.
See above.
17x7 w/ 215/50R17
17x11 w/ 315/35R17
then a
This is my daily driver:
Front: 17x7 with 215/50ZR17
Back: 17x11 with 315/35R17 Toyo DRs
Here are some more pics, I removed the IMG tags from these since there are so many. I am using a UMI adjustable PHB to center the rear, and the fender lips have been rolled:
http://images51.fotki.com/v1545/phot...MG_1296-vi.jpg
http://images52.fotki.com/v1568/phot...MG_1323-vi.jpg
http://images52.fotki.com/v1567/phot...SC_0697-vi.jpg
And here are some pics from before I cut the springs 1 coil and did the rear hose mod. The height and gap almost makes it look like they stick out from the wheel wells, but they don't. With it lowered, it looks flush.
http://images49.fotki.com/v1520/phot...MG_1043-vi.jpg
http://images46.fotki.com/v1506/phot...MG_1044-vi.jpg
http://images49.fotki.com/v1520/phot...MG_1045-vi.jpg
http://images49.fotki.com/v1521/phot...MG_1039-vi.jpg
http://images49.fotki.com/v1521/phot...MG_1040-vi.jpg
http://images50.fotki.com/v1570/phot...MG_1280-vi.jpg
http://images51.fotki.com/v1550/phot...MG_1283-vi.jpg
http://images51.fotki.com/v1560/phot...MG_1284-vi.jpg
http://images52.fotki.com/v1554/phot...MG_1291-vi.jpg
http://images51.fotki.com/v1550/phot...MG_1300-vi.jpg
http://images52.fotki.com/v1568/phot...MG_1316-vi.jpg
http://images50.fotki.com/v1572/phot...MG_1319-vi.jpg
http://images51.fotki.com/v1561/phot...MG_1321-vi.jpg
http://images51.fotki.com/v1562/phot...SC_0708-vi.jpg
http://images51.fotki.com/v1560/phot...SC_0710-vi.jpg
http://images50.fotki.com/v1559/phot...SC_0699-vi.jpg
http://images24.fotki.com/v873/photo...SC_0687-vi.jpg
http://images24.fotki.com/v873/photo...SC_0713-vi.jpg
http://images24.fotki.com/v873/photo...SC_0714-vi.jpg
http://images50.fotki.com/v1573/phot...SC_0714-vi.jpg
http://images51.fotki.com/v1545/phot...MG_1356-vi.jpg
http://images51.fotki.com/v1546/phot...MG_1362-vi.jpg
http://images51.fotki.com/v1560/phot...MG_1364-vi.jpg
http://images52.fotki.com/v1552/phot...MG_1365-vi.jpg
I painted my brake calipers black with silver CAMARO decals since taking those pictures too:
http://images52.fotki.com/v643/photo...MG_1571-vi.jpg
Old 12-21-2009, 09:04 AM
223HAWK's Avatar
Somedays I wish I would have got 7s up front but I like how tuff itlooks with the 9.5s up front!
Old 12-21-2009, 09:24 AM
Photochop's Avatar
They look awesome man, can't wait to get a set later next year.
Old 05-16-2013, 12:53 PM
Rise of the Phoenix's Avatar
Can anyone give me the correct bolt pattern and back spacing for the BS Street Lites for my 02 WS6? I acutally made a new thread asking the same question, but stumbled upon this thread when I was searching I'd like to get the 17x8 and 17x11 combo.
Quick Reply: 17" Billet specialties questions.
