C5 Z06 rim offsets???
ok so im getting rims and tires soon and i have a few questions about the offsets...i want the rims to be flush with the fenders..not tucked and not sticking out past the fenders...so i found 2 sets of rims and im curious which would be better fitment for my 95 Z...i just want to kno which offsets would allow the rims to be flush with the fenders..if i need to put spacers in then ok but i would like to get them as flush as possible..thanks alot! here are the 2 sets.....
1) 17 x 9.5 offset 54mm
18 x 9.5 offset 56mm
2) 17 x 9.5 offset 54mm
18 x 10.5 offset 58mm
well, as you may know both front rims options are the same, so no choice there. If you want the rim to be as close to flush as possible get the 10.5" rear rims. The 9.5s and 10.5s you listed are only have a 2mm difference in offset but the 10.5 inch rims is 1 high wider, so 0.5 inches wider on each side which translates to 12.7mm closer to where you want it to be, flush with the fender.
With the 10.5s you can run 295 width tires, with the 9.5s, only 275
