JEGS Sport Lites,Summit Stars
I'm looking into Summit Stars or Sportlite's(JEGS) and I was wondering if anyone is running these? How do they like them? How much do they weigh per wheel compared to the Weld Prostar's? Are you on factory Studs? What size tire you running?
Any help would be great.
Running the Summit Stars on my car. Factory studs, using an acorn lug with a small shank. They are about 4-5lbs heavier than the Prostars. Fronts fit without any grinding or spacer on my LT1 and the rears fit over my pre-ground calipers.
I'm running a 28x11.50R15 ET Street on some 15x10's. But since you have a camaro I wouldn't go with anything but the 15x8. The 15x10's have a 6.5" BS and will stick out too far on a camaro.
Running 15x8 w/ 5.5 bs summit stars w/ hardly any grinding. And for tires im running 275/50/15 MT drag radials. O yea, and using factory studs w/ stock lug nuts.
i have the summit stars 15x8 rears with 26x10.5x15 mt et streets and some greg weld drag stars 15x3.5 with kumho tires. i just bought them a few weeks ago, went to the track and pade 5 passes and mabye 100 street milles, the fronts fit w/o grinding. the rears fit with a small amount of grinding. im selling the car and dont need them, there yours for 900
Here is my brothers trans am. He likes the wheels alot! They did not need anything special to put them on. Stock everything. I didn't even have to grind the calipers. But the vehicle is lowered like 2 inches all the way around.
https://ls1tech.com/forums/appearanc...ag-wheels.html
