Got cheater slicks and still cant hook!!!
Old 04-25-2009, 09:24 PM
Restricted User
1BAD_LS1's Avatar
Default Got cheater slicks and still cant hook!!!
Got some M&H Racemasters DOT cheater slicks 305/40/16 and i still cant hook worth a **** on the street at 20-25psi....
I can still burn them up till around 40mph.... I even tried to heat them up for like 20 seconds!!!!
I have tried flashing.... and 1500, 2000, 2500rpm footbrake.... nothing seems to work!
I had about 1/4 tank of fuel and the car is full weight.... mods are in sig...
I am dissapointed in them honestly. the only thing i can think of is that it was only 40 degrees outside.....
Is there something else i can try?
Old 04-25-2009, 09:27 PM
madmike9396's Avatar
get you some 15 inch rims and i have some Hoosier slicks i will sell you. they came off a late model circle car. id bet they will hook like a mother. im gonna try them when i find some rims i like. he gave me 8 of them
Old 04-25-2009, 09:56 PM
Restricted User
1BAD_LS1's Avatar
not looking to buy anything else for my car till i get my rear bought... Just wondering if anyone had any tips for me... lol
is it even possible to hook good on any tire on the street?????
Old 04-25-2009, 10:19 PM
rice4eatingnotdrivin's Avatar
did u try using a little VHT??? also with it being 40 outside thats not gunna help... we had the same problem with my car last year when it started to get cold out...
Old 04-25-2009, 10:24 PM
Restricted User
1BAD_LS1's Avatar
No i have not.... does it really work as good as claimed and do i have to apply it everytime i wanna launch?
Old 04-25-2009, 11:58 PM
aug181983's Avatar
Old 04-26-2009, 12:13 PM
nd4spd22's Avatar
Lower your air pressure. Way too much for slicks.
Old 04-26-2009, 12:28 PM
JonCR96Z's Avatar
It's hard to hook anything in 40 degree weather. Get some adjustable shocks, it'll make a big difference. You could try running more gas and/or take some weight of the front to help with weight transfer. Still have the front sway bar?
Old 04-26-2009, 01:16 PM
69_YENKO's Avatar
+1 I've been running around at 15psi on the street on my ET Streets. I recently played around with uping the pressure to 18 and its doesnt seem do quite as well but its not bad either. Im putting 450/425 to the wheels N/A, I had to start running around on my ET Streets because my BFG KDWs dont do anything but spin.
just dont try to go carve corners and end up busting the bead of the wheel.
also 20sec worth of a burnout is a bit much. you can over do it just making the slicks gooey and not hook at all.
Old 04-26-2009, 07:00 PM
Restricted User
1BAD_LS1's Avatar
ya ill try to lower the pressure even more and remove the front sway bar.... the cold im sure isn't helping
will try VHT if nothing else helps... hopefully itll start warming up soon here in nebraska...
Old 04-26-2009, 07:09 PM
nastychevelle's Avatar
are you running the stock torque arm?
Old 04-26-2009, 07:23 PM
Restricted User
1BAD_LS1's Avatar
yep stock torque arm till i get my rearend....
Old 04-26-2009, 07:29 PM
jetlag's Avatar
lca relocation brackets
Old 04-26-2009, 07:31 PM
Restricted User
1BAD_LS1's Avatar
I dont have those but i didn't think they were needed if your car is not lowered...
Old 04-26-2009, 07:34 PM
jetlag's Avatar
They help any car.
Old 04-26-2009, 07:45 PM
Restricted User
1BAD_LS1's Avatar
ok i think im gonna make some relocation brackets at work and try them.... hopefully this will help with the lowered tire pressure and removal of the sway bar.....
Old 04-26-2009, 08:35 PM
ybaslo1's Avatar
If you remove your front sway bar, your car is going to turn like an f'n boat. Try it and see if you like it. When I did mine, it went back on 10 minutes later.
Relocation brackets, Lower tire pressure, VHT and a warmer road should do the trick. Launching on a cold road and that high of tire pressure - I wouldn't even see a stock car hooking that great.
Old 04-28-2009, 12:39 PM
Super Speed's Avatar
Cold weather isn't exactly good for traction
Old 04-30-2009, 04:20 PM
meine96ws6's Avatar
the weather is a factor... wait until it heats up until you do anything drastic.. and save for the rear..
Old 05-16-2009, 11:56 PM
Restricted User
1BAD_LS1's Avatar
got a warm day and got it to kinda hook but the 10 bolt blew! so im looking for a 9 or 12...
