Jegs/Summit Draglite style wheels
I have not seen anyone run them, Do they clear the calipers on LS cars? I found a set locally for really cheap and just wanna see if anyone else has them?
I have Summit Stars and they fit you just have to use a air grinder and grind some of the edges of the calipers if you go with the 15" wheels anything larger you should not have to do any grinding.
I just put a set of Summit Sport Slot's on the front of my 2002 with no problem. The calipers had been ground to fit Weld Pro Star, but now I don't need a spacer. Sure would like to get a set for the rear, but not sure if they will fit.
