stock suspension fbody pics...how low can u go
looking to do 3 things at one time. 1st i am trying to find out how much i can narrow my rear end on my 98 z28 WITHOUT touching the factory wheel well. minor banging and loosing the stops is not a problem.2nd i am trying to figure out the correct offset wheel for said rear .if i know the maximum that i can narrow the rear end on stock suspension the backspacing should be easy to figure out but any input would be appreciated,3rd and last how low can you set the ride height on these things? this will be a drag radial style ride.looking to put 15x10 on rear and 15x3.5 on front.i also want the rear tires to be tucked under rear quarter panel not hanging out the sides looking all retarded.i know with a stock lengh rear end a 15x10 with a 7.5 backspace is the norm. just not the look im goin for.any help would be appreciated,thanks christian
