Shank Style Lug Nuts are breaking studs
Old 05-28-2009, 11:21 AM
mattl31's Avatar
Default Shank Style Lug Nuts are breaking studs
Hey I was wondering if any of you guys had any guesses as to why my shank style lug nuts keep breaking off studs on my 01 TA
The wheels are Billet Specialties Street Lites, and I'm using the lugs that were sent with the wheels. They always go on just fine, I torque them, then when I go to remove them, every now and then there is one that WILL NOT come loose. I'm pretty frustrated as this is getting expensive. I cant figure it out!
Old 05-28-2009, 11:37 AM
BETTER THAN YOU's Avatar
i am wondering the same thing. mine do it to
Old 05-28-2009, 11:51 AM
mattl31's Avatar
interesting....billet specialties also? or just shank style lugs?
so far ive only had a problem on the rears
Old 05-28-2009, 12:54 PM
Camaro396's Avatar
What studs are you using? I have ARP 3.250" studs and have had mine on and off around 1,000 times and never had any issues.
Old 05-28-2009, 02:01 PM
mattl31's Avatar
just stock studs. i know they arent great but at 400 wheel horse i havent thought about changing them yet.
Old 05-28-2009, 03:44 PM
Camaro396's Avatar
I broke my stock studs leaving off the limiter in my 300hp Mustang.
Old 05-28-2009, 11:43 PM
Unstang's Avatar
I knew I had at least 1 messed up stud when I put the Street Lites on last week for the first time.
I did it at the track with my Bogarts. I went to pull the wheels off tonight, one lugnut is stuck & 1 stud is ruined. I'm going back to ARP studs...Had them in my stock axles before, but didn't switch them when I went to the Moser's. I'm leaving the car home this weekend...
Old 05-29-2009, 06:42 AM
Old 05-19-2011, 11:09 PM
Ryan33187's Avatar
To bring this back from the dead... so did the ARP studs fix everyones problems because this is getting very expensive for me. I have probably changed all the studs on the rear 2 or 3x now, and replace the mags a few times.
Old 05-20-2011, 12:34 AM
speedracer2536's Avatar
yes.. When going to almost any drag wheel you need to upgrade the lugs..
Old 05-20-2011, 12:36 AM
Ryan33187's Avatar
You mean studs?
Old 05-20-2011, 09:24 AM
Lugs, studs you know what i meant.. You upgrade both anyway
Old 05-21-2011, 09:42 PM
s25hanh's Avatar
how do you change the rear studs? I tried the other day and couldnt understand how. I took off the tire, rotor, then i was left with the e-brake shoes and I was lost there. I didn't know how to access the studs
Old 05-22-2011, 05:05 PM
NBM99SS's Avatar
You hammer them out............then pull the new ones in.
Old 05-22-2011, 05:15 PM
Customizing Director
MadIceV8's Avatar
If you do not install these perfect then they will crack your stud. Do not use any power tools. Thread them in entirely by hand and then follow with a torque wrench.
Old 05-22-2011, 10:33 PM
s25hanh's Avatar
how to you get the E-brake drum off the axle?
Quick Reply: Shank Style Lug Nuts are breaking studs
