Just bought 18x10.5 oem z06 wheels,(SPACER?!)
so just wondering what spacer will give me the nicest look for my new z06 wheels that i will be installing.
i know that they can fit without any spacers but i want a really nice stance i was thinking that maybe with my fenders rolled and some 5/16 spacer should do the trick?
the tires are 295s pzeros but also want to have a good fitment for 305 or 315s.
pictures are welcomed!
also if anyone knows what kinda of wheels studs i will need for a 5/16 spacer?
i want ARP studs
and would i need new wheel studs with a 1/4 spacer?
thanks!
i want ARP studs
thanks!
i already have the front wich are aftermarket 17s.
so i know they will fit but i hear you need to hammer in the inside a bit to solve rubbing issues and i want them to be flush with the fender.
what brand and type of spacer should i get?
well my bro has 11 zr1 and the stance is
and looking at his 315s i want to stick mine out for a better stance too!
also felt one of my wheel studs in the back slipping so should be time to switch im going with arp studs thanks to 99Bluz28 for giving me the part number.
studs will be about 30 bucks..
spacers not sure i seen some from $6 all the way to 80 dont know which to get yet..
should get all this done in a moth or 2 since i still need to powedercoat my wheels black.
hum only 2 lol i have 17x9.5s all around so finally got a 2 oem 18x 10.5 for the rear that i will be powdercoating black.
if anyone need 2 17 9.5 black z06s i will let them go...
if not might make it my dd setup or drag set up.
update i bought the arp-100-7708 was about 25bucks
5/16s wheel spacer for 13bucks
and sent in the wheels to get powder coated all black.
now just need to roll my rear fenders i think im going to rent a fender roller.
I have some wheels from OEM, and the rears are 18x10.5's with a 56mm offset. I put on some 7/16 spacers in the back today with new studs. I'm now going a full inch bolt on spacers because there is still a good half inch before its flush with the fender lol. Tires are 295/35's. Looks good with the 7/16's spacers, but could look better with another half inch.
are they c5 Z06 tho? because i know the c6 are really deep inside my friend put like a 1" adapter bolt on spacer on it on his ws6.
also Camaros smaller fenders from what i recall. and i want it so that i am able to fit 315s with no problems
yea I believe mine are the c5 with 56mm offset. I think the c6 are like 59mm? a bit more. I think if you put a 1" spacer on it you'd be able to fit 315's no problem. But might have to roll the rear fenders.
