Rear wheel studs seem to short for 1.5" spacer.
I purchased 2 sets of wheel spacers 1" for the front and 1.5" for the rear. I found that the front wheel studs stuck out 1/4 inch more than the outer surface of the wheel spacer and the rear studs only allow 3/4 on the nut to fasten. I'm not sure what I should do? should I get shorter studs in the front and longer in the rear? seems like alot of work.
assuming you have the bolt on spacers, cut the fronts to be flush with the mounting surface, and get longer studs for the back, which you might need to cut after the bolt is fully fastened.
