torq thurst 2's
Old 06-09-2009, 01:59 PM
00 black ss's Avatar
Default torq thurst 2's
i need to order these rims fast. i want 18 x 10 in the back and 17 x 9 in the front. the backs would fit nitto 555r 305/35/18 tires right? and the fronts would fit 275/40/17 tires? i just dont know which ones to order? can someone help me out. heres all the ones they have on their site. which would fit these tires on a ls1 camaro
BACK
VC405817345 18x10 Custom 5x127
VC405816572 18x10 Custom 5x114.3
VC405816570 18x10 Custom 5x114.3
VC405816567 18x10 Custom 5x114.3
VC405816565 18x10 Custom 5x114.3
VC405816560 18x10 Custom 5x114.3
VC405817360 18x10 Custom 5x127
VC405816562 18x10 Custom 5x114.3
VC405817347 18x10 Custom 5x127
VC405817350 18x10 Custom 5x127
VC405817352 18x10 Custom 5x127
VC405817365 18x10 Custom 5x127
VC405817357 18x10 Custom 5x127
VC405817362 18x10 Custom 5x127
VC405817367 18x10 Custom 5x127
VC405816557 18x10 Custom 5x114.3
VC405816157 18x10 Custom 5x120.7
VC405817355 18x10 Custom 5x127
VC405816155 18x10 Custom 5x120.7
VC405816545 18x10 Custom 5x114.3
VC405816172 18x10 Custom 5x120.7
VC405816170 18x10 Custom 5x120.7
VC405816167 18x10 Custom 5x120.7
VC405816165 18x10 Custom 5x120.7
VC405816162 18x10 Custom 5x120.7
VC405816152 18x10 Custom 5x120.7
VN405816170 18x10 39 7.04 5x120.7 (5X4.75)
VC405816555 18x10 Custom 5x114.3
VC405816150 18x10 Custom 5x120.7
VC405816147 18x10 Custom 5x120.7
VC405816145 18x10 Custom 5x120.7
VC405817370 18x10 Custom 5x127
VC405817372 18x10 Custom 5x127
VC405816550 18x10 Custom 5x114.3
VC405816552 18x10 Custom 5x114.3
VC405816160 18x10 Custom 5x120.7
VN405817355 18x10 1 5.54 5x127 (5X5.0)
VN405816165 18x10 27 6.56 5x120.7 (5X4.75)
VN405816567 18x10 33 6.80 5x114.3 (5x4.5)
VN405816570 18x10 39 7.04 5x114.3 (5x4.5)
VN405816572 18x10 46 7.31 5x114.3 (5x4.5)
VN405817345 18x10 -24 4.56 5x127 (5X5.0)
VN405817347 18x10 -18 4.79 5x127 (5X5.0)
VN405816562 18x10 20 6.29 5x114.3 (5x4.5)
VN405817352 18x10 -5 5.30 5x127 (5X5.0)
VN405816560 18x10 14 6.05 5x114.3 (5x4.5)
VN405817357 18x10 8 5.81 5x127 (5X5.0)
VN405817360 18x10 14 6.05 5x127 (5X5.0)
VN405817362 18x10 20 6.29 5x127 (5X5.0)
VN405817365 18x10 27 6.56 5x127 (5X5.0)
VN405817367 18x10 33 6.80 5x127 (5X5.0)
VN405817370 18x10 39 7.04 5x127 (5X5.0)
VN405817372 18x10 46 7.31 5x127 (5X5.0)
VN405817350 18x10 -11 5.07 5x127 (5X5.0)
VN405816145 18x10 -24 4.56 5x120.7 (5X4.75)
VN405816150 18x10 -11 5.07 5x120.7 (5X4.75)
VN405816152 18x10 -5 5.30 5x120.7 (5X4.75)
VN405816155 18x10 1 5.54 5x120.7 (5X4.75)
VN405816157 18x10 8 5.81 5x120.7 (5X4.75)
VN405816160 18x10 14 6.05 5x120.7 (5X4.75)
VN405816162 18x10 20 6.29 5x120.7 (5X4.75)
VN405816565 18x10 27 6.56 5x114.3 (5x4.5)
VN405816167 18x10 33 6.80 5x120.7 (5X4.75)
VN405816147 18x10 -18 4.79 5x120.7 (5X4.75)
VN405816172 18x10 46 7.31 5x120.7 (5X4.75)
VN405816545 18x10 -24 4.56 5x114.3 (5x4.5)
VN405816547 18x10 -18 4.79 5x114.3 (5x4.5)
VN405816550 18x10 -11 5.07 5x114.3 (5x4.5)
VN405816552 18x10 -5 5.30 5x114.3 (5x4.5)
VN405816555 18x10 1 5.54 5x114.3 (5x4.5)
VN405816557 18x10 8 5.81 5x114.3 (5x4.5)
VC405816547 18x10 Custom 5x114.3
FRONT
VN4057956565 17x9 33 6.30 5x114.3 (5x4.5)
VN4057956157 17x9 14 5.55 5x120.7 (5X4.75)
VN4057956162 17x9 27 6.06 5x120.7 (5X4.75)
VN4057956165 17x9 33 6.30 5x120.7 (5X4.75)
VN4057956167 17x9 39 6.54 5x120.7 (5X4.75)
VN4057956172 17x9 52 7.05 5x120.7 (5X4.75)
VN4057956555 17x9 8 5.31 5x114.3 (5x4.5)
VN4057956557 17x9 14 5.55 5x114.3 (5x4.5)
VN4057956160 17x9 20 5.79 5x120.7 (5X4.75)
VN4057956562 17x9 27 6.06 5x114.3 (5x4.5)
VN4057957370 17x9 46 6.81 5x127 (5X5.0)
VN4057956567 17x9 39 6.54 5x114.3 (5x4.5)
VN4057956570 17x9 46 6.81 5x114.3 (5x4.5)
VN4057956572 17x9 52 7.05 5x114.3 (5x4.5)
VN4057957357 17x9 14 5.55 5x127 (5X5.0)
VN4057957360 17x9 20 5.79 5x127 (5X5.0)
VN4057957362 17x9 27 6.06 5x127 (5X5.0)
VN4057957365 17x9 33 6.30 5x127 (5X5.0)
VN4057957367 17x9 39 6.54 5x127 (5X5.0)
VN4057956560 17x9 20 5.79 5x114.3 (5x4.5)
VC4057956562 17x9 Custom 5x114.3
VN4057957372 17x9 52 7.05 5x127 (5X5.0)
VC4057956155 17x9 Custom 5x120.7
VC4057956157 17x9 Custom 5x120.7
VC4057956160 17x9 Custom 5x120.7
VC4057956162 17x9 Custom 5x120.7
VC4057956165 17x9 Custom 5x120.7
VC4057956167 17x9 Custom 5x120.7
VC4057956172 17x9 Custom 5x120.7
VC4057956555 17x9 Custom 5x114.3
VC4057956567 17x9 Custom 5x114.3
VC4057956565 17x9 Custom 5x114.3
VC4057957372 17x9 Custom 5x127
VN4057956155 17x9 8 5.31 5x120.7 (5X4.75)
VC4057956570 17x9 Custom 5x114.3
VC4057956572 17x9 Custom 5x114.3
VC4057957357 17x9 Custom 5x127
VC4057957360 17x9 Custom 5x127
VC4057957362 17x9 Custom 5x127
VC4057957365 17x9 Custom 5x127
VC4057957367 17x9 Custom 5x127
VC4057957370 17x9 Custom 5x127
VC4057956557 17x9 Custom 5x114.3
VC4057956560 17x9 Custom 5x114.3
Old 06-09-2009, 03:01 PM
Bump.... Anybody know which ones will fit these tires and the car? And where to order from?
Old 06-09-2009, 07:06 PM
Southernsnow's Avatar
call the place or go to a wheel and/or tire place and ask them... they will normally know or can help you out... just my thoughts on it since i'm not going to go through that list, check out a sticky to find out what the lug pattern is... everything you need to know should be in the "Wheels and Tires: everything you should need to know is in here sticky"
but heres the link for you
Old 06-09-2009, 07:26 PM
sr71's Avatar
the lug pattern is 5x120.7mm. the fronts are 17x9.5 with a 7" backspacing. for an 18x10 rear with a 305 tire, I would run a 7.5" back to make sure it tucks properly and then use a spacer if needed to get the tire to fender lip clearence perfect.
it's hard to get anything from ar right now, let alone anything custom. Jason at dragwheelz.com would be the best guy to talk to.
Old 06-09-2009, 07:34 PM
BlkBird2000's Avatar
TT2s only come in 17s. You have to order custom TT2s in 18s.
Old 06-09-2009, 07:37 PM
sr71's Avatar
yeah and they are backordered on 17x11's right now, so I would hate to see what the wait is for custom build wheels.
Old 06-09-2009, 07:55 PM
Where do I order custom tt2s and how long would they take?
Old 06-09-2009, 10:04 PM
DriftR's Avatar
Originally Posted by sr71
the lug pattern is 5x127mm.
F body lug pattern is 5x4.75 or 5x120.65mm(5x120.7) ^let's just call that slip a typo!
Old 06-10-2009, 01:31 AM
I have no idea. Do a search on here.
Old 06-10-2009, 12:40 PM
Donohue96M6Z28's Avatar
Probably about 8 wks, but you'd have to call an actual shop to confirm.
Old 06-10-2009, 05:07 PM
sr71's Avatar
yes, lets. my typing sux after 12 hrs at work.
Old 06-10-2009, 07:42 PM
Black FormulaLs1's Avatar
www.OEWheels.com they are a sponsor on here i beleive?
