How To Jack Up?
Old 06-29-2009, 01:37 AM
Crimsonnaire's Avatar
Default How To Jack Up?
Hi, everyone.
I understand that with F-bodies, you have to be careful where you position the jack to prevent possible damage to the chassis. On that note, can someone please tell me where to position a jack (or even the type of jack more suitable than others) on the front end to lift up one side just high enough to be able to remove the wheel?
I saw mechanical jacks listed on the Autozone website, are those suitable for a 4th generation F-body?
Any advice is appreciated.
Old 06-29-2009, 01:59 AM
litemup02's Avatar
I just use a regular 2 1/2 ton floor jack under the k-member... Its slow at first..cuz you dont get much for pump but it works. or if you only want one at a time, hit the frame right behind the lower fender tabs that hang down. Located behind the front wheel. Dont catch the tabs with the jack
Old 06-29-2009, 08:23 AM
spy2520's Avatar
The tabs say "DO NO JACK" so make sure you miss them or you'll be searching on how to get the bulge out of your front fenders.
Old 07-01-2009, 08:36 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
this may help
http://www.installuniversity.com/ins...ift_points.htm
Old 07-01-2009, 09:57 PM
Awesome tutorial!
I'm new to cars, so even something as simple as where to place a jack helps me. Thank you all for the clarification.
