Longer stud question
I'm looking at the arp studs, the 2.5" length ones. It says they are 1" longer than stock ones? I should be able to use my current lug nuts then correct? They are only on by a few threads now. The wheels are 17x9.5 c5 z06 knockoffs. Is 1" more adequate?
Oh yeah, second question. I won't damage anything by hammering all 20 studs out correct?
The fronts just pop out. A steel punch may make it easier. I'm not sure the backs are as easy. I've never done those, but it looks like you may have to remove the axles.
The length is good if you ever need to run spacers, but i think the biggest benefit is the material they are made out of.
I just recently installed the 070-100-7708 on the rear of my car. Just popped out the axles, knocked out the old ones, and installed the new ones. Didnt take very long at all, and was really easy.
