Telstars?/?/?
Old 07-02-2009, 04:21 PM
Rafko's Avatar
Default Telstars?/?/?
Got a set of telstars and was wondering if i needed to run longer wheel studs or if the stock one will work?
Old 07-02-2009, 05:41 PM
6SSPEED's Avatar
Not sure bout the studs but I do know that you have to either grind the heck out of the rear LS1 brakes or swap to LT1 rear brakes to get them to clear.
Old 07-02-2009, 10:54 PM
Firewood's Avatar
I just removed my telstars. 15x4 on the front and 15x8 on the rear. Had to grind like crazy to make them fit. Put a 5/16 spacer behind the fronts and installed longer studs but the rear fit fine with stock studs other than the fact that i twisted two sets of those. Here is the only pic I can find right now.
Attached Thumbnails Telstars?/?/?-l_d7470b440845a79c94ecd4e1660b9120.jpg
