zr1s on my 98 ws6
Old 07-25-2009, 06:54 PM
bigc98ws6's Avatar
Default zr1s on my 98 ws6
what do i have to do to fit the 17x11 zr1s on the back?
Old 07-25-2009, 07:17 PM
LS199CAMAROZ28's Avatar
At stock height I'm pretty sure all you need is an adjustable panhard bar. If your dropped you may have to roll the fender lip and use a BFH on the inner fenders.
Old 07-27-2009, 09:25 AM
LS1Tech Platinum Sponsor
OEWheelsLance's Avatar
Our wheels shoud fit a STOCK 98 TA without modifcation. The specs are in the provided link - OE Wheels - ZR1 Selection
Old 08-03-2009, 07:58 AM
RiceEaterZ's Avatar
I've Got the 17x9 17x11 ZR1's on my 02 camaro, and The only issue I had was slight rubbing on the inside driver side Rear 315, So I am running small 5mm spacer, and just Because I'm a do it 1 time kinda guy, I went ahead and also have !BFH, Rolled inner & Outer fenders, SLP bumpstop "jounce" spacer,(not sure if that is helpful, might just reverse that) and a tad bit of angle grind on the bumpstop. (I'm pretty sure I can fit more than 315 back there
Goodluck, some guys have Zero fitment issues, Hope you're one of em
Either way, They look Badass with some Meats
