How to run different size tires in the back
Anyone know a simple way to disconnect the ABS so I can run different size tires in the back? Last time I ran 295s in the rear and like 225s in the front and the ABS INOP light and my BRAKE light came on once I hit like 55mph. When I hit my brakes my car darn near bounced off the road from vibrations and it ended up warping my front rotors. I like the way it looks with nice wide tires in the back so any1 know how to do it without spending loads of money?
Ok well it’s nice to know that it can at least be done I wasn’t to sure if it could. Now I just got to figure out how. So if any1 can help with that please do it'd b much appreciated.
It doesn't have to do with tired width. It's tire height thatcauses issues. So if you have a 18 wheel in the back and 17 in he front you want to run a 35 tire in the back and a 40 in the front
yea, like twitch said, it has nothing to do with the wheel width, but the height. i had 295/45/17s (27.2 tall) on my car with 275/40/17s (25.6 tall) up front. the ABS light and TCS light went on because the rear tire was too tall, and the sensors couldn't figure it out. Width doesn't matter. I have 165/80/15s up front now with 275/50/15s out back with zero issues because they are both roughly around 26 inches tall
u can get ur car's pcm calibrated for the correct size, but u need something like a hypertech or diablosport (which IMO aren't worth the money). u can have ur dynotuner fix it with HPTuners I believe
