15x8s or 15x10s wheels and 26'' or 28'' tires
hey you guys I'm thinking of getting some welds on my 98 z28 but don't really know what would fit and also look good i want the hot rod look so im going 15x4s in the front but need help for the back also my car is an a4 and im planning to do my gears very soon so if i go 28''s il go 4.10s gears if 26'' then 3.73s i need some info on how they fit and or if its difficult to fit and in your opinion which would work better
please post any pics that you have of these wheel and tire sizes so that i have a clue of how it will look thank you in advance!!!!!
You can buy my two front convo pro's 15x4 front runners
There are plenty of nice drag wheel set-ups like weld, billet specialties, centerline, bogart, etc. Some require grinding of the calipers and some don't.
Also, the measurements for the F-bodies are
Front- 4.75" bolt pattern and 1.75" backspacing
Rear- 4.75" bolt pattern and 7.5" backspacing (also depends on how much you shorten your rearend and all that good stuff) but stock it's 7.5"
As Steve said 15x10s. 15x8s limit your tire choices severely, and look stupid IMO. Which Weld wheels are you looking at? The new RT line from Weld Racing will fit over stock brakes with no modifications.
Here are Weld Racing Weldstar R/T wheels.
Heres the same setup, with a 17" Weld Alumastar front.
Welds new RT line also comes with a black finish option.
But heres a complete list of all the new wheels that are offered from Weld Racing that are designed for the LS1 brake calipar.
hey thanks for the info and pics!! now if i go 28s on 15x10s how hard or what do i have to do to fit them and what do you guys think of the summit wheels they look like a good bargain any problems with thos by the way i daily drive the car and go to the track like 2 times a month so would the 28s help me out after i do the gears at the track??? thanks again
the thing is that im working on a budget im only 18 so money is pretty tight right now so that mite be the best choice for me rite now but if i were to get them whats the fitment problem with them im most probably gonna go with the 15x8s in the back with a 26x10 r15 tire does any one know if that would fit and looks good??????? if any pics of that combo please post oh and im going 15x4s in the from dont know what tire would look good tho
You will have to grind on your brake calipars using the summit wheel, and will be limited to the 15x8 wheel. If you mean 275/50/15 drag radial, that tire is best fitted on a 10" wheel. And I'm only 19 too, but I decided to save up for correct fitting made in America wheels.
