Will this wheel fit a F-Body? PLZ HELP!
Seen these wheels that I ran across and I just had some fitment questions. Its made by Niche and they call it Venice. Size I was wondering about are 18x8.5 and 18x10 but the bolt pattern is 5x120 with a offset of 20. I know the right size for our cars is 5x120.65 but also seen F-bodys that had wheels with a bolt pattern of 5x120 on their car like the ADR M-sport n others. Will 5x120 fit or pushing it to much.
The 5x120 will fit but the problem your going to have is the offset. That 20mm offset is going to make the wheels stick way out and you may have issues with rubbing the wheel well up front when turning. Check out the sticky, 38mm is the smallest recommended:
https://ls1tech.com/forums/wheels-ti...must-read.html
I'm about to do the same. Also wondering. This totally a noob question an Im sure is all over this forum but if someones going to comment again please.. What is the best off set to get the most FLUSH look Front/Back?
