What length ARP studs for Weld wheels?
Old 07-27-2009, 08:05 PM
Lt4TransAm's Avatar
Default What length ARP studs for Weld wheels?
Im running a spacer in the front with weld draglites and was wondering what length wheel studs i need to buy?
Old 07-27-2009, 08:43 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
depends how far you want them to stick out. You can get either the 2.5" or 3.25"
Old 07-27-2009, 11:50 PM
Camaro396's Avatar
I use 3.250 studs. With my Prostars they came right to the end, flush with my lug nuts. With my Alumastars, they use a really short shank lug, and no spacer, so they stick out a bit. But the 3.250s are perfect for Draglites/Prostars with a spacer.
Old 07-28-2009, 12:23 AM
Lt4TransAm's Avatar
What about when i put my 10 spokes on will the 2.5's fit under the cap.
Old 07-28-2009, 09:02 AM
Camaro396's Avatar
Nopeee. The 2.5s and 3.250s will both not fit under the caps. Found that out when I went to put mine back on.
