What size skinnies up front
Old 08-06-2009, 10:58 AM
03 BUSA's Avatar
Default What size skinnies up front
Decided to go with a 26 * 11.5 in the rear. Are you guys running the same size for the fronT (26)?? Or going with something shorter like a 24/25? Any pros/cons to doing either? Thanks for the help.
Old 08-06-2009, 11:27 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm running a 26x7.5 on the front of my CETA
Old 08-06-2009, 11:43 AM
03 BUSA's Avatar
^^^With 26's in back
Old 08-06-2009, 12:12 PM
Camaro396's Avatar
I've always ran 26" front tires, even with 26", 28", and 30" rears.
Old 08-06-2009, 01:16 PM
03 BUSA's Avatar
Thanks guys.
Old 08-06-2009, 01:19 PM
StreetSilverado's Avatar
I'm running 26x7.5 up front and 28's in the rear
Old 08-06-2009, 01:55 PM
jmm98LS1's Avatar
My car is pretty low up front with 26x6x15's and 28x12.50's out back, I'd be dragging my air dam along the road with anything shorter!
Old 08-06-2009, 04:08 PM
Z28/2002's Avatar
I'm running 27x11.5 Hooisers in the back
Old 08-06-2009, 05:03 PM
SIC LSX's Avatar
mine are 26x6.5's also known as 165/80 kumos have over 7 k miles and love then 26.5 x 11.6 on rear of my car. If i had 27 or 28's on rear i would have a 27"front tire its just to much of a difference. My air dam hit speed bumps and dips in the road but never exhaust or frame
Old 08-06-2009, 06:53 PM
03 BUSA's Avatar
Next question. How wide in the front? I was looking into the 26 x 4.5 x 15 for the fronts. Too narrow?? I see some of you guys are running some wider fronts on your setups??
Old 08-06-2009, 08:03 PM
SIC LSX's Avatar
i personally wouldn't ever run anything skinnier then 6-6.5" unless its a track only car
Old 08-06-2009, 10:19 PM
Camaro396's Avatar
It depends what kind of tires. A 26x4.5-15 M/T ET Front is actually wider than a 26x7.5-15 M/T Sportsman front.
Old 08-07-2009, 10:29 AM
03 BUSA's Avatar
Looking at the M & H setup.
Old 08-07-2009, 11:27 AM
Camaro396's Avatar
I have M&H radial skinnies on my 17x4 fronts. Nice tire.
