LS1 caliper grinding question
Old 09-25-2009, 01:20 PM
PKC-Z71's Avatar
Default LS1 caliper grinding question
I'm looking into getting some Weld Draglites for my old heap (99 Z28), and I know I need to do some "surgery" to the front calipers to make them clear those wheels. But instead of grinding on them with a high-speed cutting wheel I want to take them off the car and cut the necessary material off of them with a mill-drill I have at work. What I guess I'm wanting to know is exactly how much material will I have to cut off the front face of the calipers so they'll clear the Draglites?
Any info will help me out A LOT! Thanks in advance!
-Paul
Old 09-25-2009, 02:05 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
It's a trial and error type thing
Old 09-25-2009, 03:30 PM
Tommyv8's Avatar
Didn't you post a pic of your calipers? I was going to use that as a guide when I grind mine to try to minimize the number of times I have to test fit.
Old 09-25-2009, 07:22 PM
Z28/2002's Avatar
Here are mine. I didn't have to grind the rear because my brake pads weren't the newest if you know what I mean.
Also take a look here
https://ls1tech.com/forums/drag-raci...ers-101-a.html
First is driver side and second is passenger
Attached Thumbnails LS1 caliper grinding question-005.jpg   LS1 caliper grinding question-006.jpg
Old 09-25-2009, 09:19 PM
Tommyv8's Avatar
Thanks!
Old 09-26-2009, 06:12 AM
Z28/2002's Avatar
good luck
Old 09-30-2009, 11:46 PM
PKC-Z71's Avatar
Thank you very much Z28/2002!!
Old 10-01-2009, 06:05 AM
Z28/2002's Avatar
Quick Reply: LS1 caliper grinding question
