Will 18x10.5" fit on fronts and work ?
LS1Tech Platinum Sponsor
"We can't guarantee it", but that set-up is all over this board. I believe they are running a 1/4" spacer in front. You can see that set-up in this thread.
3/16" spacers are perfect, but it also depends on the tires, Im running 295's up front and its great. You wanna use the smallest spacer possible if your using wide(295+) tires or else they will stick out to much. You can actually fit 315s on the front (and be able to rotate them with the rear)
jegs sells their brand of spacers for good prices, Just remember you SHOULD use stronger studs (arp studs) if you use spacers, Its worth the extra $$$
I'm running a 1/2" spacer, and I would say that's the perfect size. It fits the wheel perfectly flush with the fender wall. I'm running a 285 right now, but I think I will swap my 315s from the rear, and get another set of 315s. I'll have more then enough space to fit the 315s up front with the 1/2" spacer.
