ZR1 17x11 LT1 to LS1 help!
Old 10-05-2009, 02:02 PM
TempleU_WS6's Avatar
Default ZR1 17x11 LT1 to LS1 help!
Ok so my friend found ZR1's in 17x11 rear and 17x9.5 fronts but they were on a guys LT1.
Now the questions are, will they fit fine one his LS1 Camaro and will he need a spacer?
Also they should go on with out any other modifications right?
He has stock everything in the rear and its not lowered so he wont have to worry about rubbing will he?
Old 10-05-2009, 03:02 PM
COOKIE MONSTER's Avatar
36 or 56mm OS, either way they will fit. The wheel wells are almost the same. The only time you have to start worrying about anything else is when you're putting drag wheels on. 15x10 etc. The LT1 Brake calipers are a little smaller than the LS1 calipers.
I had 17x11 ZR1s on my 94' TA, I put them on my 2001 Ws6. Plug and play!
Old 10-05-2009, 03:09 PM
Ok cool. So what about a spacer?
Old 10-05-2009, 03:59 PM
jrob56's Avatar
no they should fit fine, depending on the tire you go with though you might have to do the BFH mod to get a little clearence. and i had to remove my bumpstops and bend the mounts down out of the way.
