LS1 brakes + 15" ?
LS1 brakes + 15" ?
I know you have grind the calipers slightly with 15x4 prostars, How much more would you need to gring with 15x5 2 1/2 bs or 15x6 3 1/2 bs pro stars?Would be even close?
Do billet specialties street lites 15x6 3 1/2 bs come close to fitting?
What the differance between weld prostar 96 series and race industries 92 series drag stars? Does one have more clearance then the other.
Yes I searched everything I found is for 15x4 and I'm looking for 15X5 info.
Thanks
Thanks
I can't answer all your questions, maybe someone else can chime in. Weld products are made in USA, race industries are Chinese made ummm stuff.
It appears you're looking for a street style setup. I'd suggest staying away from welds drag series wheels and consider a street/strip setup. If you want to stay with weld, choose welds streets/strip RT series wheels. I don’t' know if the larger sizes front wheel sizes are designed to fit around your calipers or not...camaro396 may know.
I can build you anything to fit your car in our Bogart Street/strip wheels from 15x3.5 all the way up to 15x17 in 1/2" increments and fit them around your calipers. I will not suggest our Bogart drag style wheels for what it appears you’re trying to do based on your questions.
Clear Calipers
Thanks
Thanks
You might want to look at those as an option?
