What size spacer?
Old 10-28-2009, 03:40 PM
Fast 95 Z28's Avatar
Default What size spacer?
Hi, trying to get my c5 z06 rims 18"x10.5" on my 98 ss without them rubbing. these are for the rear tires only. i was thinking an 1/8" spacer. and i forgot im running a 295/35/18 tire. what do you guys recommend?
Old 10-28-2009, 07:49 PM
anyone?
Old 10-29-2009, 04:13 AM
Engine_HP's Avatar
need more info than that,
whats ur BS/Offset.
Old 10-29-2009, 05:09 AM
MurderedOut's Avatar
whats ur BS/Offset.
Should be 56mm on those wheels. A 1/8" spacer should do it, might have to grind a little on the bump stops, maybe bang on the wheel wells some.
Im running the same size wheels on mine on a 56mm offset with 3/16" spacers, except im running 315/30/18s. Use a 3/16" if you wanna be safe, they will still fit inside your fenders if you do(should probably roll them). However, it is recommended to upgrade to longer studs (arps) when you use spacers. I did.
Old 10-29-2009, 02:06 PM
i read somewhere that it was safe to run 1/4" spacers on stock studs. and since my tires are 10mm smaller than urs, like you said the 1/8" should probly work fine.
Old 10-30-2009, 07:49 PM
was experimenting with my tires today. i bought some washers at lowes to get a ballpark guess of how much a spacer i need. i think the 1/8" spacer is cutting it to close. i would like to get 3/16" spacers but can't find them anywhere. since im worried about getting a 1/4" spacer because I have stock studs. one more weird thing the driver side rear tire fits fine without any spacers. do i need to put spacers on both sides so the wheel base isnt out of balance?
Old 10-31-2009, 04:48 AM
Engine_HP's Avatar
looks like u need to get the adj PHD and maby some adj LCA, to get ur back axle centered.
and YES, u need to put spacers on both sides.
if u cant find spacers custum cut a one for u, here: http://www.motorsport-tech.com/
Old 10-31-2009, 03:11 PM
my car has stock suspension why would I need to buy those adjustable pieces? isn't it alright since that is the way it came from the factory?
Old 10-31-2009, 03:38 PM
Engine_HP's Avatar
bcz u said that ur back axle is off-balance,
so i asume the passenger side is rubing, why bcz ur axle is not centered, Why is ur axle not centered??? I dont know, there many reasons to that.
