5/16" Wheel spacer with stock studs?
Old 10-30-2009, 04:59 PM
sgm98ws6's Avatar
Default 5/16" Wheel spacer with stock studs?
I just bought a set of oem y2k wheels for my bird. Instead of beating my wheel wells i decided to go with a 5/16" spacer. I know people have said that the 1/4 is fine with stock studs but I havent seen anything about 5/16" spacers. Will I be fine with these its only a little over .06" difference but I hadnt heard of anyone using these.
Old 10-30-2009, 11:03 PM
hitmanws6's Avatar
you are running those at your own risk. people have snapped studs with those
Old 10-31-2009, 04:09 AM
tspence45's Avatar
I'm running 5/16" spacers on, as far as I know, stock studs. I'm not really sure if they're stock studs though, because they seemed to grab a lot of threads with them. I'm thinking of getting some conical/shank style lug nuts though, just to be on the safe side.
Old 10-31-2009, 09:54 AM
69TA's Avatar
NO don't do it!
stock studs are really weak to begin with and
kind of short since the threads don't go to the end.
so running a spacer on there is a bad idea.
Old 10-31-2009, 12:11 PM
Camaro350z2897's Avatar
i was also thinkin about running the same spacer. but was wondering if i should just go ahead and have longer/stronger studs installed.
Old 10-31-2009, 12:50 PM
sgm98ws6's Avatar
thanks guys i had a newb moment fitting the wheels. I used the stock jack and when i put the wheel on in the back it rubbed. " I didnt lower the car to load the suspension and level the rear axle out" But once i lowered the car down it had 1/4 inch or more clearance between the tire and inner fender. so thanks to my adj. pan hard bar my wheels are good.
Quick Reply: 5/16" Wheel spacer with stock studs?
