1/4" spacers where to buy?
just want my rear wheels to come out a little bit i have 275's in the rear and if i lower it i know they will scrub anyone know a good place to buy some for not too expensive?
Be aware that if you have stock studs that you loose the spacer width on the stud when you put the lugs back on. So with a 5/16 spacer or two (if you double them up) you will loose at least 5/16 inches of thread on each stud as well.
A stock 1 1/2 inch stud doesn't leave much open thread after installing the rotor and the wheel + the spacer.
