BS street lites from dragwheelz
Old 11-02-2009, 06:54 PM
94-z's Avatar
Default BS street lites from dragwheelz
I just installed my wheel tires but they hit the bump stops for the rear end. Is there an easy fix for this problem? Or did they send me the wrong tires.
Old 11-02-2009, 10:00 PM
87silverbullet's Avatar
I am assuming you have the 15x10 with the 7.5 inch backspacing? If so you need to remove the bumpstop. Mine was gone when I got the car and I have the 15x10 with no issue.
Old 11-03-2009, 12:58 PM
94-z's Avatar
so just whip out the old cutting wheel yea they are the 15x10
Old 11-03-2009, 03:48 PM
99FBODY's Avatar
I had 15x10 prostars and had to cut the bumpstops as well.
Old 11-03-2009, 05:01 PM
Camaro396's Avatar
I have 15x10 7.5 backspace weld RT wheels with 325 drag radials and mine don't rub. They will if I jack the car up, put jackstands under the chassis, and let the rear end fall. But when I jack it up I always put stands under the rear, or remove the rims before dropping the rear.
Old 11-03-2009, 05:15 PM
DopdBrd's Avatar
That's right.
To the OP, try doing that, I bet they will fit just fine if you jack up the rear and not the body.
Old 11-03-2009, 06:53 PM
94-z's Avatar
Yea I might look into it car hasn't been sat down in 2 years so we will see
Old 11-04-2009, 06:14 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I had to cut the bumpstop as well with mine.
FWIW: I'm running a 27x11.5 Hoosier
