side wall height? 18x8.5", 19x10"
I am planning on getting some Deep Dish C6 Z06 rims, 18x8.5" up front, 19x10" rear. They are going on my 2002 camaro SS. It has been lowered 1.2" with strano springs. I was just wondering what sidewall height would i need for the tires? Would it look stupid if the rear tires had less sidewall than the fronts? like 35 series in the fronts, 30 in the rear? or if im gunna get 30 in the rear, should i also get 30 in the front? thanks for any input.
Right now on my TTMs (17") I have 9.5" wheel i am running a 275/40 and on my 10.5" wheel I have a 315/35
Now when I buy my C6 wheels (18") on my 9.5" wheel I am going with a 275/35 and on the 10.5" wheel I am going with either a 295/35 or a 305/35..
Remember you want the wheel to have the same diameter as your OEM tire: 245/50/16 = 25.6"
EDIT: I just read that your rear tires were going to be 19s.. dunno if what I said above applies to you now.. Sorry
well since my rears are going to be 19s but have a much smaller sidewall than the stock tires, the overall diameter is only going to be slightly bigger, something like .3", if i go with 30 for the sidewall.
275/30/19 or 285/30/19 on the rear 19x10's and 255/35/18's on the front 18x8.5. 245/40/18's just looks odd on the front size because the sidewall is A LOT bigger than the 30 series on the rear. However, be warned that the ride is horrendous with a 30 series tire...been there, done that, will never do it again and now I'm back on 18's.
i plan on running the same size rims. I emailed tirerack and they suggested a 245/40R18 for the front and 265/35R19 for the rear.
Ive always asked them for many cars and they've never let me down.
Anyone see a problem with these sizes? Should look good no?
Ive always been told you want more sidewall on the rear tires than the front if your doing staggered rims, or it will look goofy. Or at least the same sidewall height.
IMO, if you want staggered wheel heights then the only way it'll look right is if the rear tire sidewall height is > the front side wall height.
For tires these are the only tire sizes I would be looking at:
Fronts, 245 or 255/40/18s.
Rears, 285 or 295/35/19s.
Wouldn't a 285 or 295 just make the overall rear wheel too tall? By over an inch if I did my math right..
how would the width of the tire make it too tall? 285 or 295 is the measure of the width of the tire, that has nothing to do with how tall the tire is. the sidewall height, the 30 or 35, determines how tall the tire will be. If i got 30 series tires in the rear, the overall diameter of the rim/tire combo would only be about .3" bigger than stock rim/tire combo, since im using a bigger rim, but much slimmer sidewalled tire.
Example: 295mm x .35 = 103.25mm
295 = tire width
35 = series
103.25mm = sidewall height
oh damn, didnt know that!
What he said..
It's just not as easy as it should be..
To me that would look bad. I don't know for sure though. Guess I'd have to see it. But on my BMW I'm running 255/45/18 on the rear and 235/50/18 on the front and it looks great. It's the same rim size though. I would think a staggered height would be expected that the rears would be smaller because rim is bigger. Shouldn't look weird. What do stock corvettes run as far as sidewall proportions?
To calculate sidewall yourself just:
multiply the percent of aspect ratio by the width then convert to inches.
40% of 245 = 98mm (multiply by .03937 to convert to inches) 3.858"
35% of 385 =99.75mm (multiply by .03937 to convert to inches) 3.927"
