Slicks and inner tubes
http://www.yellowbullet.com/forum/fo...play.php?f=107
Originally Posted by SmokedOutZ28
Whats the downside to not using tubes?
-air will leak out over time
If you run tubes, you really should run rim screws. If you don't screw them and the tire moves on the rim and moves the tube with it, the valve stem could shear off.
I have never ran tubes in my cars in the past.
drag radials have worked very good for me and many other way faster then my car
Butch I would really try to use a radial as the car will be faster over a slick.
