bad vibration with welds
I just got a set of weld draglites and both have brand new tires and they are all 4 balanced. I get a bad vibration at around 60 mph and it only gets worse the faster I go. The wheels are not bent and everything is balanced but yet it still shakes like a **** around 60 mph. Is this normal with skinnies and spacers up front? I traded for these wheels lastnight and had zero vibration before all the way up to 130 mph. I had the z06 motorsports.
I would do all 4 to make sure it is right. Discount Tire may have the equipment, call them first. If not call the biggest wheel dealer in your area, someone should know how to do this. An adapter is required for the balancing machine for your bolt pattern. The wheels will center off the lugs and so it makes sense to balance them this way. Good luck, let me know how it goes.
