how to fit 19 x10 0n the back?
Old 12-20-2009, 11:04 AM
bigc98ws6's Avatar
Default how to fit 19 x10 0n the back?
i have a ws6 and i am going to upgrade to the zo6 19X10 what would i have to get to make sure they fit.
Old 12-20-2009, 11:22 AM
'Trust''s Avatar
Well a 19x10 will fit no problem. A 19x12 could be different, what are your offsets and back spacing on the 19x12. I had 17x12's on the black T/A, but the offsets and bs (unknown to me, bought them used) were perfect, no rubbing or BFH mod, but you may not be as lucky.
Old 12-20-2009, 11:28 AM
DriftR's Avatar
19 x 10 (in your thread title) and 19 x 12 (in your post) are 2 different things...
19 x 12 ZO6 is gonna need the BFH mod to the front of the rear inner fenderwell and probrably remove the bumpstops (not recommended) and should be at stock height because they stick out past the fender lip (not preferrred).
I haven't mounted a set though, this is just from my obsevations... I have 19 x 10 C6's with 1.25 adapters. I saw one thread with pictures of the ZO6 12's, try a search?
Old 12-20-2009, 11:34 AM
DriftR's Avatar
beat me to it...
OEM C6 10" is 79mm offset, the ZO6 12's are a similar offset to the F-body offset, so that extra width is split 1/2 to the inside, 1/2 to the outside of the mounting surface = very tight fit!
