15x10 6.5 bs lowered w/26in
Old 01-09-2010, 01:30 PM
draggin97s10's Avatar
Default 15x10 6.5 bs lowered w/26in
like it says would this work if so i need pictures came across a killer deal on 15x10 6.5 bs. what tire would i have to run im lowered about 2 in the rear
Old 01-09-2010, 05:02 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You are going to run into tire/fender clearance issues
Old 01-09-2010, 09:08 PM
DroppedM6Z's Avatar
I did it on a 2" drop....I had QA1's set on 2 and they touched little on the nittos, never touched the ET streets
btw tires in pics are 275 555R's that SUCKED *****
17" Z0's
Old 01-10-2010, 11:15 AM
thank you very much
Old 01-10-2010, 11:17 AM
btw that cherry picker is really clean lol.
Old 01-10-2010, 02:09 PM
Camaro396's Avatar
I wouldn't do it. My 7.5 backspace wheels rub a little, 6.5 backspace would be asking for a highspeed blowout if you hit a bump IMO..even with 26s.
Old 01-10-2010, 02:29 PM
01SOMZ28's Avatar
My car is lowered with BMR springs and my slicks rubbed bad when i would hit a bump. You're going to have to roll your fenders, i never rolled mine and thats where they rubbed. The slicks were 26x11.5x15 ET Streets.
Old 01-10-2010, 02:32 PM
any others?
Old 01-10-2010, 02:33 PM
wont be 11.5 either
Old 01-10-2010, 02:34 PM
im going to machine them down a little too. i dont know how much ill be able to take off but well see
Old 01-10-2010, 03:28 PM
DroppedM6Z's Avatar
it was 1.5 hrs old at the time pic was taken...did the job very well
Old 01-10-2010, 03:50 PM
hah i figured it was. mine looks like it came from WWII
Old 01-11-2010, 08:38 AM
bump anyone else
Old 01-11-2010, 09:39 AM
Camaro396's Avatar
Why do you keep bumping the thread? You already have your answer. Several people have told you it rubs too badly to be safe.
Old 01-11-2010, 09:52 AM
yes one other person did besides you but they are running a 11.5 wide tire and im going to mill down the mating surface of the rim so ill probably be in the 6.75 to 6.825 bs area just wondering if anyone else had pictures tha is all. you seem like your in a bad mood alot do you want a hug
Old 01-11-2010, 09:54 AM
or i guess i could just spend the extra money so im not limited to tire size
Old 01-11-2010, 10:11 AM
ryarbrough's Avatar
Have you ever seen the back side of a prostar or draglite/how they are made? I assume this is what you're planning on using. You're not gonna be milling much of that off without having issues....
Old 01-11-2010, 10:20 AM
its actually a racelite and havent inspected the back yet. but i have mill some other wheels and it worked. ill probably just go ahead and buy something with the proper backspacing. prolly wont be worth the time messing with it
Old 01-11-2010, 02:13 PM
Camaro396's Avatar
What brand wheels are they? And I'm not in a bad mood, I just wouldn't want to steer someone in the wrong direction to where they could have a blowout and end up injured or killed. Save up and get the correct fitting ones. I use 15x10 7.500" backspace and they even rub when I hit a big bump.
Old 01-12-2010, 09:59 AM
weld but im not getting them im just gonna do what u said and go with the 7.5 back space. lot less problems alot more tire options
Quick Reply: 15x10 6.5 bs lowered w/26in
