Will a 16" billet specialties street lite fit over the LS1 front brakes?
Seems like you have to grind to fit a 15x4" billet specialties wheel over the front brakes. No grinding is required for the 17", but sometimes the 17/15" combination looks a little off if the front is not lowered. Planning on running a 15" rear with a 28" tire.
Seems like the 16x4" front wheel should work pretty good, but will it fit without any grinding of the calipers?
LS1Tech Co-Founder
The grinding for 15x4's was minimal, I think if you do 16x7's, you are not gaining anything. You'd be running 235's up front and so the front wheel/tire combo would basically weigh the same as stock:
