Are these right for a 99 Z28??
Old 01-26-2010, 09:39 AM
sujomatt's Avatar
Default Are these right for a 99 Z28??
Fronts: http://www.summitracing.com/parts/SUM-521-5461PS/
Rears: http://www.summitracing.com/parts/SUM-521-5861PS/
And also, what size tire would be recommended for these? Going to be mostly street but of course strip too.
Thanks!
Old 01-26-2010, 10:27 AM
rtr2001ss's Avatar
Well, my only comment is the first link, the bolt pattern is off. It's 5x4.75 all the way around. Other than that, 15's on an LS1 is probably going to require some grinding.
Old 01-26-2010, 10:33 AM
sujomatt's Avatar
Oops, copy pasted the wrong 1 for the fronts - thank you for catching that lol (updated)
Grinding what exactly for the 15's? They are only 8" wide in the rear - thanks for the help!
Old 01-26-2010, 11:55 AM
9WhiteCamaro9's Avatar
grinding the brake calipers so they will clear and wont scrub the inside of the wheel and the caliper
Old 01-26-2010, 12:42 PM
sujomatt's Avatar
Ahhh gotcha - Yea I am curious if anyone has had that issue or not with these.. I figure its a cheaper alternative to Prostars lol
Old 01-27-2010, 10:37 PM
i cant tell about that now lol ive not had a set of those before lol but i think you have to grind em for Welds and Bogarts but im sorry i cant help you on that one
Old 01-28-2010, 03:11 AM
uphigh07's Avatar
you will have to grind but you can make them fit no worrys
Old 01-28-2010, 04:12 PM
i was thinkin i heard that before but i didnt wanna lead him the wrong way and all so i left it up for someone else that would better know lol but thanks for the info as well UpHigh07 i was wonderin that myself cause i may be orderin a set sooner or later lol
