widest tires for 8 inch rim???
Old 01-29-2010, 01:32 PM
supersean's Avatar
Default widest tires for 8 inch rim???
I just ordered a set of the jegs magg num rears in 8 inch since the 10 inch has the wrong bs. so my question is what is the widest, best looking tires i can put on??? pics wuld be great, i know its a small set up tho
Old 01-29-2010, 01:51 PM
sujomatt's Avatar
well do you want sticky tires? I have MT ET Streets currently.. i am going to be grabbing those wheels probably after i see some pics of yours on and im thinking about putting the ET streets on those too
Seems to fit 8" wide 15" rims: http://www.summitracing.com/parts/MTT-3762R/
Old 01-29-2010, 03:45 PM
Slash8915's Avatar
Well, the widest STREET tires I'd recommend are 245's. I'm sure you could fit a little wider, maybe 255's or even 265's, but I wouldn't recommend it. My last wheels were 18x8.5 up front, and I could fit 265's no problem. Now I run 17x9.5 up front with 275's and 18x10.5 in the rear with 295's. I'd like to go wider in the rear, but don't want to do any modifications.
Old 01-29-2010, 05:46 PM
kierstyn's Avatar
275s is about the biggest you want to run on a 8in rim. I have them on mine and they look great!
Old 01-29-2010, 06:39 PM
Camaro396's Avatar
No.
No.
You're first question needs to determine tire height. What gears do you use What transmisison? What RPM do you shift at?
If you want a 26" tire:
You can run Mickey Thompson 26x11.5-15 ET Streets
You can run Mickey Thompson 275/50r-15 ET Street Radials
If you want a 28" tire:
You can run Mickey Thompson 28x11.5-15 ET Streets
You can run Mickey Thompson 275/60r-15 ET Street Radials
If you're really making power, and want a 30" tire:
You can run Mickey Thompson 30x12.5-15 ET Streets
You can run Mickey Thompson 295/65r-15 ET Street Radials
You can run Mickey Thompson 315/60r-15 ET Street Radials
Old 01-29-2010, 07:17 PM
Slash8915's Avatar
Originally Posted by Camaro396
No.
No.
Well I was just talking about everyday street tires. Not drags or street radials.
Old 01-29-2010, 07:52 PM
kierstyn's Avatar
Ah thats why all these guys on here are running a 275 on a 8in rim? Ah well im going to pick up some slicks anyways! lol Also why you say no to mine then post 2 275 tires? lol
Old 01-29-2010, 11:48 PM
Camaro396's Avatar
You said the biggest you want to run is 275s on a 8" rim.
I have 295, and 315 radials on a 8" rim.
Old 01-30-2010, 07:49 AM
supersean's Avatar
Im looking to get a dr....i saw where M/T has a 295 55/15 that can fit an 8 inch rim. does anyone have a pic of these on a car???? maybe you have a pic camaro396???
Old 01-30-2010, 10:23 AM
Camaro396's Avatar
These are a fairley new tire, so I havn't seen them yet. But they sound like they would work out good.
Old 01-30-2010, 10:34 AM
kierstyn's Avatar
Ah ok I thought you meant that the 275 was to wide! I thought about doing the 295/50/15s and was told by alot of people they were to wide for a 8in rim. I would like to do them if thats not the case!
Old 01-31-2010, 02:43 PM
supersean's Avatar
would M/T dr's be too sticky for my stock rear??? ive just got a bolt on car with a stall going in, got over 100k on the car and dont exactly wanna dead hook and kill the rear lol
Old 01-31-2010, 03:57 PM
kierstyn's Avatar
I have a buddy that runs the m/t dr with a stock rear and a 3800 stall he pulls 1.6 60fts on motor and 1.5 on the spray its still in there.
Old 01-31-2010, 04:52 PM
supersean's Avatar
well mine wont be leaving that hard lol should be alright then i suppose
Old 01-31-2010, 07:26 PM
00FlowCamaro's Avatar
I have an 8.5" rim and the biggest i was told to go was 255.
Old 01-31-2010, 07:32 PM
Camaro396's Avatar
I still have a 10 bolt with my M/Ts and 5200 stall.
Someone lied to you.
Old 01-31-2010, 07:35 PM
SexyTransAm's Avatar
im still tellin ya 275 or 295 is the way to go! but ya need to fig out if ya want 26in or 28in. and with ur stock gears im thinkin 26in. then slam that bitch
Old 01-31-2010, 07:36 PM
lol hell i had a 275/50 on a 7.5 in wheel at one point.
Old 01-31-2010, 07:39 PM
syclone2882's Avatar
def would think 275 is the max
Old 01-31-2010, 08:01 PM
supersean's Avatar
i just wanna see an 8 inch rim with M/Ts new 295/55!!! these are what im really leaning towards since there for a 8-10 inch rim
Quick Reply: widest tires for 8 inch rim???
