Are tubes recommended when running slicks?
Old 02-21-2010, 01:20 AM
01SOMZ28's Avatar
Default Are tubes recommended when running slicks?
I was curious if its recommended that you run a tube in slicks? I bought a set of slicks already mounted on wheels a while back. I then purchased a different set of wheels to put the slicks on and while i was dismounting the slicks they had tubes in them. I went ahead and used them when mounting them on the new wheels.
But a friend of mine recently bought some slicks already mounted on wheels as well. He was also dismounting his slicks to put them on a different set of wheels and when he got the slicks off they had no tubes in them?
So just like the title says, are tubes recommended or not?
Old 02-21-2010, 01:22 AM
13lu91rS's Avatar
if the tire says "tubeless radial" then tubes arent required, is the easiest way to answer that.
usually if the tire has a bead, a tube isn't required. but if the slick "sits" on the rim then yes, use a bead.
Old 02-21-2010, 12:42 PM
jonlisa973's Avatar
Yes, depends on the tire though.
Old 02-22-2010, 10:59 AM
bww3588's Avatar
we have 2 rails and a S-10 at school, all 3 have MT ET drags on that "require" tubes, but there arent any in there. i dont run any in my tires either. i just soap the tires before i mount them to keep it from leaking down.
Old 02-22-2010, 11:06 AM
ndfrsd6's Avatar
i run them in mine ..... much more stable on the top end , not necessary but they do help
