18 x 10.5's Z06's... what tires will fit?
Old 06-17-2010, 08:24 PM
trik396's Avatar
Default 18 x 10.5's Z06's... what tires will fit?
I've got 18 x 10.5's with 275/35R18's right now and they need changing. This is on a 2000 TransAm WS6 Ram Air, if that matters. How big can I get away with using these rims? I like the look of a 275/40R18 cause it fills in the wheel well a little more but can I go wider like a 295/40 or ???
Please help because I need to pick out these tires this weekend if possible. I have a couple hundred mile run I need to make and the tires I have now (F1's) are VERY dry and cracked and I don't trust em'.
Thanks
Old 06-17-2010, 09:59 PM
cookba's Avatar
275's are too small for a 10.5" rim. slap on some 305's
this is on the back right?
Old 06-17-2010, 11:55 PM
Customizing Director
MadIceV8's Avatar
You should be running a 295/35/18 on that sized rim, that tends to look best as well.
Old 06-17-2010, 11:59 PM
1993 z28 f1's Avatar
Hey:
Do you have 10.5s on all four corners, if so 285/35 or 40/18 Nittos 555s, 05s or Invos, all the way around.
Dub
When In Doubt Do Without
Old 06-18-2010, 07:57 AM
ta-stanger's Avatar
I have 295-35's on the back of mine with out any issues!
Old 06-18-2010, 08:49 AM
trik396's Avatar
10.5's all around... should've stated that... sorry... now I'm really confused. How big can I go ALL around without any issues?
Also, maybe I'm old school... I like the 35's now BUT I think I'd like a 40 for just a bit more sidewall to fill in the well...
Opinions... pics???
Thanks
Old 06-18-2010, 08:56 AM
ta-stanger's Avatar
Like stated ^ I'm thinking 285 in front are about MAX!!!
Old 06-18-2010, 09:14 AM
cookba's Avatar
285's in front, 295 or 305's in the rear. i know from experience a 275/40/80 rubs the wheel well in the front a little but no damage.
Old 06-18-2010, 09:17 AM
meine96ws6's Avatar
I was running a 275/35/19 in front of mine with no issues!!
Old 06-18-2010, 09:23 AM
trik396's Avatar
Thanks guys.... looking into Nitto 555's in 285/40R18 or 35's....
Old 06-18-2010, 10:33 PM
Hey:
I have Nitto 555s, 285s all round 35s in the front and 40s out back with a spare pair of NT05r 315 35 18 for the rear for track use, All on 10.5 rims. Don't go any bigger than 285 for the front as that may even rub a little, 315s in the rear but may have to BFH and/or use spacers, roll lips, depending on the car. I had Nt05s all around and liked them better than the 555s.
Dub
Old 06-19-2010, 04:18 AM
9WhiteCamaro9's Avatar
im not tryin to steal this from the OP but what size would yall suggest for 17x9.5 all the way around cause i got 275/40/17 on it now and was just tryin to get suggestions on leave or go bigger
Old 06-20-2010, 04:19 PM
los p's Avatar
i put 305 35 18 on the back and i had some issues but i got it to work and it was all worth it in the end! but that was with stock ride hight
Old 06-21-2010, 12:00 AM
Hey:
285 is the widest tire recommed for 9.5 wheels, so 285 or 275 are fine IMHO in 35, or 40 if you like a taller tire and better ride.
Dub
Old 06-24-2010, 12:55 PM
rouchiemanz28's Avatar
275's in front and 305's in the back
Old 06-24-2010, 02:37 PM
ybaslo1's Avatar
IMO, if your doing the same style tires, I would do a 295/35/18 rear and 275/35/18 in the front. You can also do a 315/30/18 in the rear (They will be wider, but shorter than the 295/35/18), Or if you want a drag radial, you can do a 305/35/18 in the rear (Will be a tad wider and taller than a 295/35/18). Do an advance search on those tire sizes and you will find some pictures of different tire types and how they fit on certain wheels. But Def do the 275/35/18 in front so you don't have any rubbing issues.
Quick Reply: 18 x 10.5's Z06's... what tires will fit?
